Go to Post Welcome to the imperfect world of design! - Joe Johnson [more]
Unread 27-10-2011, 14:34
Dkt01's Avatar
Dkt01 Dkt01 is offline
Programming Mentor
AKA: David
FRC #1756 (Argos)
Dkt01 will become famous soon enough
[FTC]: [FTC]: No teleop code
Hey everyone,
We've been trying to run our robot wirelessly through the Samantha FCS and every time we connect we get an error that says our NXT has no teleop code. What should the teleop vi be named in LabView? Also, is there a way to do real-time debugging and data viewing (on front panels) like the crio allows?
We are using Labview, and this is our rookie season, so we're trying to figure out how everything's supposed to work.
Thanks
Unread 27-10-2011, 21:41
aj4112b aj4112b is offline
FTC #4112
aj4112b is an unknown quantity at this point
Re: [FTC]: [FTC]: No teleop code
run the autonomous chooser program from the try me files on the nxt, and pick your teleop program, then press start match on the fcs and it should work
