Go to Post The purpose of this forum is for us to communicate our ideas, so that we can collectively strengthen our ability to inspire others. - Jaine Perotti [more]
Unread 28-10-2011, 15:37
smcmahon's Avatar
smcmahon smcmahon is offline
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
Team Role: Coach
smcmahon is an unknown quantity at this point
Question [FTC]: Common FTC tools
Greetings,
My name is Sean and I'm coaching FTC rookie team 5526 this season. What are some common tools and/or materials we should purchase? We've got a 5th year FRC team in our high school also, so we have the general tools one might need to build an FRC bot. Can you think of anything we might not have that we will need? Or anything we might need 2 or 3 of? Things we're like to break or work through?
Thanks for lending your experience!
FRC 2656 | FTC 5526 | VEX 9656
Unread 28-10-2011, 22:53
kz2zx kz2zx is offline
Ruthlessly Insufficient
FTC #5246
Team Role: Coach
Rookie Year: 2011
kz2zx will become famous soon enough
Re: [FTC]: Common FTC tools
Offhand:
Drill press, sheet metal shear, sheet metal brake, sheet metal roll, bandsaw, table saw, carbide wheel for skil saw or table, holesaws, cordless drills, nutdrivers, t-handle allens, x-acto, razor blades, soldering iron/station, VOM/DMM, powersupply, laptop, router (both the kind that removes wood and the kind that supports a wireless network), drill bits out the wazoo, various forms of channel-locks, pliers, vice-grips, chainbreaker, punch, tap & die set, hacksaw (metal and diamond-rod), mitrebox, radial arm saw, strippers/snips, crimpers, spring clamps, angle grinder, dremel or diecutter, heatgun, DA sander/compressor, sanding drums, pop rivet gun, cable cutters, needle, thread, sewing machine, c-clamps, three-or-more-axis mill, printed circuit cad, laser printer, torch.
I think I'm forgetting a few.
Unread 29-10-2011, 02:09
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Rookie Year: 2007
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
Originally Posted by kz2zx View Post
Offhand:
Goodness dude, thats more tools than my FRC team has... Seriously.
However he does have a point, one might run across the need to use those if doing very intricate engineering with the FTC bots (except the mill).... But if you want to get technical with the fun tools like CNC Lathes, Breaks, Water and Laser Jets are tons of fun to!
But in all seriousness we operate out of a house and have had anywhere from a drill press, belt sander, manual break, bandsaw and ones assortment of tools to accomplish our tasks. And any of the extra fancy stuff is normally sponsor owned (wish I had a water jet). I think you should be pretty set if you have an FRC team backing you.
- Andrew
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 29-10-2011, 14:34
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
The only tools you absolutely NEED in FTC, in addition to to what you have from FRC are:
-->A lot of small hex keys, color coded if possible, The tetrix system uses no fewer than 3 or 4 different sizes, it is really annoying.
-->appropriately sized nut drivers (thankfully, tetrix only uses one size of nut. Nut drivers will make assembly much quicker.)
-->sheers for cutting thin plastic sheet (great for quick additions)
-->a heavy duty hole punch for making holes in the plastic sheet so that it can be zip-tied onto the robot.
As far as materials are concerned, you should invest in tetrix shafts and nylon spacers, you can hardly have enough. Also, it helps to have a few sheets of (insert favorite, non-reinforced thermoplastic here) in .125" thickness (that is the max allowed thickness) or less for both prototyping and use on the actual robot.
Unread 29-10-2011, 15:39
FTC #5246
Team Role: Coach
Rookie Year: 2011
Originally Posted by Joyride_67_1902 View Post
(except the mill)
We've used my homebuilt turntable and xy table for pulleys and (nylon) sprocket manufacture, and if we ever needed to build a sensor or more-complex pc board, we'd use (the xy) to mill the board and avoid wet chemistry processes with the kids.
FWIW, every one of those tools we've used this year for Bowled Over!
(we're in my home garage, too. The sheet metal machine was the hardest - I'd rather outsource to a sponsor next time than buy it again, but we have it for future use, now. We do use a cheapie manual 18" brake a lot, too.)
Unread 01-11-2011, 14:22
normalmutant's Avatar
normalmutant normalmutant is offline
AKA: Nathan
FTC #3539 (Say Watt?)
normalmutant has a spectacular aura aboutnormalmutant has a spectacular aura about
When it comes to fashioning custom parts, we typically just use a sawsall or hacksaw. Metal files are essential.
SAY-WATT.ORG
Unread 10-10-2012, 22:09
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
FRC #1629 (GaCo: The Garrett Coalition)
PhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond repute
Hi Sean.
I'm Phil, coach for FTC2818 (G-FORCE) and mentor for FTC4240 (Techno Clovers)
I'm tracking down FTC teams in Western PA to see if you're interested in competing in a western Maryland Qualifying competition. Here are event details: http://mtrek.GEARSinc.org Please spread the word to other teams in your area.
Thanks.
Phil.
Originally Posted by smcmahon View Post
Greetings,
Phil Malone
Garrett Engineering And Robotics Society (GEARS) founder.
http://www.GEARSinc.org
FRC1629 Mentor, FTC2818 Coach, FTC4240 Mentor, FLL NeXTGEN Mentor
Unread 16-10-2012, 13:05
smcmahon's Avatar
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
Team Role: Coach
Thanks for the offer Phil. Sounds like a great event.
We're about 2 hours from your event. I'll run this past my FTC team at Thursday's meeting this week.
Unread 31-10-2012, 21:55
Telthien
Posts: n/a
It's worth noting that our team got 2nd in the World Championship in 2010 (Get Over It) with nothing but a dull hacksaw and dremel.
Just saying, tools are useful, but they're tools, not dependencies. Bad design can't be compensated for with fantastic tools.
