Go to Post Though winning is not the end, that doesn't mean it's not important. - Michael Corsetto [more]
Unread 05-11-2011, 21:28
WizenedEE's Avatar
WizenedEE WizenedEE is offline
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Team Role: Leadership
Rookie Year: 2010
WizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to all
What is Windriver?
Hello,
My team is looking into using C++ next year, but I was confused as to what the purpose of Windriver is. Couldn't we just download WPILib, then use a text editor and batch files/makefiles to compile and upload the code? I'd rather avoid having to install a 2.4 gigabyte, windows-only, propitiatory IDE when vim is available.
Unread 05-11-2011, 21:47
connor.worley's Avatar
connor.worley connor.worley is offline
FRC #0973 (Greybots)
Rookie Year: 2010
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: What is Windriver?
It's eclipse based. You could probably circumvent it.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 06-11-2011, 06:15
Wind River is the company name, and their website name.
Wind River Workbench is one of their products, an integrated development environment for the VxWorks operating system that the cRIO runs.
Workbench is an integrated collection of pretty standard tools, customized for embedded development. Many of the elements can be ignored or substituted if you are already familiar with the tools and wish to change things up.
I encourage you to visit their website to read more about the OS and other tools they offer.
Greg Mckaskle
Unread 06-11-2011, 13:20
WizenedEE's Avatar
AKA: Adam
Rookie Year: 2010
So it seems like that, when actually programming, we can just use a text editor and gcc to make sure it compiles. Then we can have the workbench on the computer that's connected to the robot for the easy uploading and fancy debugging. Does that sound right?
Unread 06-11-2011, 20:55
You can certainly use other text editors. Using another compiler may be tricky - getting the correct header file paths and lib paths. Invoking the Wind River gcc from a command line or other scripted tool should be pretty straightforward.
Greg McKaskle
Unread 03-12-2011, 13:49
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
Your favorite text editor and regular makefiles will work fine. That is how we do it. Greg is right about the compiler. You could generate a cross-compiler that would work but you need all the vxWorks and WPI headers and libraries. So just use the compiler they give you.
HTH
Unread 04-12-2011, 14:09
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Rookie Year: 1997
jhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond repute
You can also use this distribution if you wish...
http://zone.ni.com/devzone/cda/tut/p/id/5694
http://digital.ni.com/public.nsf/all...2575CC0076A230
The FRC controllers run VxWorks 6.3.
-Joe
Unread 06-12-2011, 13:20
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Rookie Year: 2011
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
So for C++ in FRC WindRivier is probably the best and easiest way to code on the robot? Also is their away to download the software, instead of installing from the CD>
Are their plugins for eclipse?
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 07-12-2011, 15:22
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
The CD essentially just contains eclipse plugins with a nice installer. So if you find the file, you can install it manually into eclipse.
You can also use any FTP client you want (ftp into 10.xx.yy.2/system/ if I remember correctly, there should be a file called FRC_UserProgram.out, replacing or deleting it downloads or undeploys your code)
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
