Go to Post "FIRST: We take young human beings, born in captivity, educate them in science and technology, and re-release them into the wild." - kmcclary [more]
Unread 06-11-2011, 17:25
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
Re: pic: FRC488's Octocanum Ver 2.0
The wheel assemblies are 1/4" ABS with .5x.5x.125" angle added for rigidity. We can laser cut the ABS parts in a few minutes; then it's simply a matter of cutting the angle to length and match drilling it to the ABS.
The bearing blocks are of similar construction, but are really ugly right now. I'm still working on those.
If possible, we'll bolt the transmissions through just one wall of the C-channel. Otherwise, we'll laser cut 1/2" ABS inserts to stick inside the C-channel to prevent it from buckling where it's bolted through.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 06-11-2011, 17:32
Andrew Lawrence
Posts: n/a
Woah.....
I have seen many amazing drive trains in my time (and I mean MANY), but this is just AMAZING! I love the idea! Are you going to implement it next year?
Just some questions:
1. How many KoP parts does it use?
2. How many other parts?
2.5 Where can these parts be obtained?
3. How easy is this to make (during build season, with a team of builders)
4. Is it open source?
Unread 06-11-2011, 17:53
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Originally Posted by Madison View Post
Our mecanum implementation worked. I didn't program it, so I can't speak too much to what made it work, but our programming team did a fantastic job there. We had accurate, fast, field-oriented drive that allowed us to fully use the movement capabilities of the mecanum wheel set. In my experience, most teams fail to achieve the level of control we managed.
Mecanum is not hard to program. It is very straightforward. The same is true of field-oriented drive.
If your robot had superior control, I suspect the reasons are probably:
1) superior craftsmanship and attention to detail of the mechanical design (wheel and frame alignment, leveling, weight distribution, minimal and consistent drivetrain friction, carefully assembled and adjusted mecanum wheels)
2) attention to detail of the electrical design (proper wiring to motors and gyro, selection of gyro with minimal drift, etc)
3) well-designed driver interface (match the driver interface to the driver)
4) skilled drivers with lots of practice
Unread 06-11-2011, 18:04
Andrew Lawrence
Posts: n/a
^ Those help too.
Unread 07-11-2011, 18:17
JohnGilb JohnGilb is offline
Programming Mentor, Drive Mentor
FRC #0488
JohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura about
Granted, the 488's 2011 machine was built quite well, but there were still all sorts of mechanical inconsistencies. The center of gravity moved around significantly as the arm moved, generally there was more weight in the back (and slightly more on the left side, I believe), not to mention occasionally getting rammed around or crashing into objects.
The base aspect of converting a desired vector/rotation into wheel speeds is pretty easy (it's even included in the WPI libraries), but we did a lot of additional work so the robot would _actually_ move the way you intended. There were many PID operations that more or less worked in concert to allow smooth robot control. It was essentially a solved problem from a theory perspective, but still required a lot of code in order to operate well.
Unread 07-11-2011, 18:36
Ether's Avatar
Rookie Year: 1969
Other than closed-loop speed control of the 4 wheels (did you do that?), what other closed loop controllers did you use for controlling the drivetrain?
Unread 07-11-2011, 18:59
FRC #0488
Initially, we had 3 closed-loop systems:
Rotational - used a gyro to keep the robot on target heading
Translational - used encoders on "follow wheels" (unpowered wheels) to gauge ground speed and keep the robot translating on a target vector
Wheel Speed - used encoders on the drive wheels themselves to achieve precise wheel speed control
After a while, we actually disabled the wheel speed, as we didn't appear to get much performance improvement from it and we were looking to save on some CPU cycles.
Unread 07-11-2011, 19:20
Ether's Avatar
Rookie Year: 1969
Were these controls presented to the driver as the interface? i.e., did the driver interface allow the driver to command for example "Translate in direction A with the vehicle pointing in Direction B" ?
Unread 07-11-2011, 20:45
FRC #0488
The driver had two joysticks:
1st: X/Y joystick movement controlled X/Y direction & magnitude of the robot relative to the field
2nd: X joystick movement controlled rotational rate relative to the robot
So, not exactly what you described, but fairly close.
Unread 07-11-2011, 21:15
Ether's Avatar
Rookie Year: 1969
OK, so let me read back to you what I hear you saying:
- You do closed-loop control of the vehicle speed as commanded by the radius1 of joystick #1
- You do closed-loop control of vehicle heading as commanded by the angle2 of joystick #1
- You do open-loop command of rotation rate as commanded by joystick #2 (X, Y, or Z axis?)
Am I understanding you correctly?
How many follower wheels did you use, and how are they mounted?
1 Do you use sqrt(X^2+Y^2) or max(abs(X),abs(Y))?
2 Do you use atan2(X,-Y) to calculate angle, or something else?
Unread 08-11-2011, 03:08
FRC #0488
Sorry, I think something got lost in my description.
-We perform closed loop control of X translation as commanded by the X axis of Joystick1
-We perform closed loop control of Y translation as commanded by the Y axis of Joystick1
-We perform open loop control of Robot rotation rate as commanded by the X axis of Joystick2 (however, when desired rotation rate is 0, we perform closed-loop control of robot angle as commanded by the heading we were at when we stopped rotating)
This was accomplished with 3 follow wheels and a gyro. Two of the follow wheels were used to track the robot moving forward/backward, and one was placed directly under the center of rotation and used to track the robot strafing.
Unread 07-11-2011, 19:15
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Wouldn't measuring the vehicle's actual velocity be more useful? After all, the drive has no care as to what wheel speed is (especially if that wheel is slipping).
Unread 09-11-2011, 10:30
Ed Law's Avatar
Ed Law Ed Law is offline
no team (formerly with 2834)
Ed Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond repute
Ether,
We tried Mecanum wheels and tried field oriented drive. It was a good exercise for our programmer who did it all on his own. It would work for 10 to 15 seconds and then the headings will be off. I think it is because of gyro drift. We use the gyro that comes in the KOP. Is there a better one that we should use? We tried a compass sensor but there is too much electro magnetic interference from the motors. Any help would be appreciated.
Please don't call me Mr. Ed, I am not a talking horse.
Unread 09-11-2011, 10:52
Ether's Avatar
Rookie Year: 1969
We're still waiting for JohnGilb to tell us what sensor his team used.
How about it, John? :-)
  #15   Spotlight this post!
Unread 09-11-2011, 15:04
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
The Discobots used the kit gyro last year to do field oriented drive on our omni-drive. We didn't have to much issues with drift over the duration of the match. We did have it setup so that the driver could zero the gyro him self at any of the cardinal directions but he only needed to use it in a few matches.
Our biggest problem with the kit gyro was the initial calibration routine we were dead in the water during a few elimination matches at Lone Star because we didn't let the robot sit still when we turned it on.
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
