Go to Post drill holes, that should fix it - E. The Kidd [more]
Unread 06-11-2011, 17:29
Thad House Thad House is offline
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
Lubrication for Open Transmissions
So we are design a custom transmission for next year, and it might be open. Is the type of grease for open transmissions different then the type for closed transmissions. If so, what type do we want.
Thanks
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 06-11-2011, 18:02
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Lubrication for Open Transmissions
It can be rather difficult to contain sometimes on the higher-speed stages near the motors. You want something with a bit of 'stick' to it so it doesn't just all fling off. Most teams use a thin coat of white lithium or moly grease, which seems to work fine. I've also heard of different teams using teflon-based lubricants. I don't have any real specific recommendation. I generally use whatever we have on the shelf at the moment and haven't had a real problem yet, with the exception of AndyMark 12-tooth CIM pinions wearing out.
Of course, there's the whole other school of thought that says any sort of 'wet' lubrication at all in an open gearbox will attract dirt and cause more wear.
Unread 06-11-2011, 18:31
Chris is me's Avatar
AKA: Pinecone
For those people, a little painter's tape will quickly (and lightly) make an "open" gearbox into a "closed" gearbox.
Unread 06-11-2011, 19:33
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
Rookie Year: 2007
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
We use light amount of white lithium grease on the gear faces. We do this frequently, and remove the dirty excess as needed. Yes, the area around the gearboxes will get dirty with splatter. Its a machine, stuff gets dirty. There is no substitute for frequent lubrication.
Unread 07-11-2011, 08:26
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Apply lightly so as to not leave lubricant on the field.
From 2011 rules
<R31> Lubricants may be used only to reduce friction within the ROBOT. Lubricants shall not be allowed to contaminate the FIELD or other ROBOTS.
Al
WB9UVJ
www.wildstang.org
________________________
