Go to Post Even in the worst times, I get a reminder of just how wonderful my big FIRST family is. - 216Robochick288 [more]
Unread 11-11-2011, 12:48
13or13 13or13 is offline
FRC #2213
13or13 is an unknown quantity at this point
What programming Language To Use??
Hey guy i have a question
what program language should we use this year.
our programer is very good in C Language but he is the only one who know how to use it so what your opinion should we use LabView this year or C++.
Unread 11-11-2011, 13:01
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Re: What programming Language To Use??
So, to be clear, is there only one programmer? If that's the case, and he knows C very well, then it's logical to use C++ instead of something else that he's not as good with.
In the end, there really aren't that many differences between the functionality of each language, so it's best to use whatever the programmer(s) are comfortable using.
Attending: MN Duluth Regional
Unread 12-11-2011, 12:54
Ashley Painter's Avatar
Ashley Painter Ashley Painter is offline
FRC #3784 (Bit by Bit)
Rookie Year: 2011
Ashley Painter is an unknown quantity at this point
Lightbulb Re: What programming Language To Use??
If anyone on your team has played with Lego Mindstorm then LabView is not very hard to use or to learn. But basically whatever langue you use, make sure your programmers learn it before kickoff.
Oh also if your programmer/s have only programmed in text based programming languages then LabView is not a good choice. Because while there are a lot of similarities between the two styles programming in a picture based programming language requires thinking about the programming differently. LabView programming ends up being very similar to making a tiered cake while text based programming is more like writing an instruction manual.
FRC Team 3784
2011 Highest Seeded Rookie
2011 Gracious Professionalism
2011 Kansas City Champions
2011 ISEF Finalist
FRC Team 3784
2012 Kansas City Champions
Unread 12-11-2011, 18:15
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
This is one of the more popular questions asked on Chief Delphi. Try using the search function for looking at threads in the last three years that discuss the pros and cons of Labview, Java, C++, Python, Lua and my favorite Robot COBOL. (Ok, so there isn't a robot COBOL).
But in prior years people have written about the issues around Mentors that know/don't know the languages, mentors that are new to robot programming, and the same set about students.
Take a look at them and then come back and ask your specific questions.
Thanks!
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 12-11-2011, 23:16
rzoeller rzoeller is offline
MN GOFIRST Recruitment Officer
AKA: Ryan Zoeller
FRC #2169 (RI3D 'Snow Problem; KING TeC)
Rookie Year: 2007
rzoeller is a jewel in the roughrzoeller is a jewel in the roughrzoeller is a jewel in the rough
Although my answer is biased (We use LV), I would say use whatever the majority of your programming team is familiar with. If it is just him, have someone younger shadow him - so that when he is gone your programming team isn't. One of the worst things that could happen IMO is that he leaves the team and not a single person can utilize and read the past code - especially if you want to modify something for off-season or use the code as a base later on. Labview allows us to focus on programming concepts and getting the ideas down - we aren't forced to deal with debugging syntax errors (and as someone who programs in C++ regularly, I can tell you that you will spend a lot of time doing just that.)
Ri3D - 'Snow Problem Programmer
FRC 2169 Alumni
Unread 12-11-2011, 23:38
Andrew Lawrence
Posts: n/a
Your ONE programmer knows C.
If this ONE programmer is the only ONE who will program this year, then C++ is the way to go.
If you are planning on having more programmers, especially those who haven't programmed much before, then LABView is an easy language to learn, so I hear.
OR, if your current ONE programmer is capable and willing, they could teach others how to program C++, however it is tough to find a good teacher in most students when it comes to programming C++.
Notice the ONE word I put in all caps? My little bit of advice to you: If you can, have more than ONE programmer. It's an important job that requires lots of work and skill, and for some strange reason robots won't run without it.
Unread 13-11-2011, 09:48
FRC #2213
we know we need more than one programmer we have one and more three that need to learn we wanted to know what program is easier to learn
Unread 13-11-2011, 09:56
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Rookie Year: 2000
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
With the templates provided, you will find that you can program a robot easily in any of the 3 languages supported. I have found that debugging is easier in Labview. You should also look to the teams nearby. It is important for FRC teams to help each other, so ask!
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 13-11-2011, 10:10
FRC #2213
ok thank you
Unread 13-11-2011, 10:27
ahollenbach ahollenbach is offline
AKA: Andrew
FRC #0103 (Cybersonics)
Rookie Year: 2010
ahollenbach is a name known to allahollenbach is a name known to allahollenbach is a name known to allahollenbach is a name known to allahollenbach is a name known to allahollenbach is a name known to all
Because the language you choose is [usually] the first language your programmers will learn in, I would recommend against LabView, but if you can't get a mentor or student who knows a different language, then LV is the way to go until you train students in a different language.
Unread 13-11-2011, 12:36
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Why? The conclusion doesn't follow logically from the premise. It seems you've left a step or two out of your argument.
