Go to Post This, right here, is why I participate in FRC. Changing lives, one corndog at a time. - Jared Russell [more]
Unread 12-11-2011, 20:13
Aren Siekmeier's Avatar
Aren Siekmeier Aren Siekmeier is offline
on walkabout
FRC #2175 (The Fighting Calculators)
Aren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond repute
Re: pic: 6wd Chassis Design
Originally Posted by Alex.q View Post
But if I eliminated the axle brackets, I wouldn't be able to slide the axles to tension the chain. That was the idea behind using them as I did.
Can't you slot both sides of the box tube like you did in one side of c-channel?
Would box tube really make it much more rigid?
Yes. At 1/8" wall it's less likely, but C-Channel will still collapse on the open side much much sooner than box tube. Think about just the profile of each of them and which would hold up better. Closed rectangle > open c.
Do you mean a cam that pushes the chain down, or do you mean a cam that rotates to push the axle brackets farther out? Assuming you meant the second thing, then I was wondering why that keeps it tight. Couln't the force just cause the cam to rotate an pull the brackets together as you described before? (I'm not saying it doesn't work, just that I don't understand why it does)
You can do either. The principle is that of the inclined plane. The angle of the cam and the friction between it and whatever it moves are such that no force exerted back onto the cam will turn it, but you can still turn the cam. Thinking of just a block on an inclined plane, given a downward force, the static friction force <= mu*tan(theta)*mg, so if mu*tan(theta) is greater than 1, then the frictional force will always be sufficient to keep the block in place, no matter what force you exert straight down. However, if you push sideways (up the ramp), you don't get the same force of friction and can move the block farther up (or farther down) at will. The block moves when you want it to, and not at all otherwise.
Unread 12-11-2011, 20:21
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
I meant the second. The forces that are pulling the chain are linear, if your chain tensioner is also linearly tensioned then 100% of the forces on the chain will be pulling on those bolts. However, a cam uses some sort of asymetrical piece on a pivot (like a bolt) as the cam turns around the bolt the radius changes relative to a point. This means that the forces required to loosen that chain must be applyed at almost a 90degree angle to the linear forces from the chain. This means only a fraction of the forces on the chain are actually doing work to turn the cam back out. If you use a bolt as a pivot for your cam then you can tighten it with a lock nut to couneract the fractional amount of force trying to turn the cam out.
We did this last year using seemless chain with great results. Ofcourse if you were really worried about the cam comming loose you could always have another cam to keep the tenision on the first cam.
Nice start on the drivetrain. I'll say that I know that C channel seems like it will work, however there is a reason that teams who use WCD's use box tubing as opposed to C channel. Generally when muliple very good teams do the same thing multible years in a row it is because it works really well. In this case you would probably do well to join the crowd. A phrase that is repeated often on my team: "The best indicator of if a design is good is if the team who used it uses it again next year."
Good luck, Bryan
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 15-11-2011, 07:34
nssheepster's Avatar
nssheepster nssheepster is offline
Da' Rule Man
AKA: Nik Shepherd
FRC #0174 (Arctic Warriors)
nssheepster is an unknown quantity at this point
Um, I'm not a super genius at this, but my team has had problems in the past with motors overheating. Wouldn't your motors heat up really fast if they're right next to each other like that? How are you dispersing the heat? Or is it just not an issue?
In theory, this should work.
In practice, not so much.
F.I.R.S.T. = For Inspiration and Recognition of Science and Technology
So really, it's F.I.A.R.O.S.A.T.?
Nah, that doesn't sound as good.
Unread 15-11-2011, 07:59
Billfred's Avatar
Billfred Billfred is offline
Running CIMs in this style is more or less standard practice; look no further than the kit's CIMple Box gearbox as evidence. Even the CIM-Sim gearbox designed for heat-a-holic Fisher-Price motors doesn't put too much daylight between the two. If you're not abusing them* (in time or in work demanded), it usually doesn't factor into the equation.
*That's not to say you wouldn't be abusing them in the context of an FRC event; many teams that go deep into eliminations find themselves resorting to ice packs or spray dusters (or I think 433 used dry ice one year) to get the temperatures down on Fisher-Price motors simply because of the tight turn-around times.
94 events (more than will fit in a ChiefDelphi signature), 14 seasons, over 61,000 miles, and still on a mission from Bob.
Unread 11-11-2011, 19:48
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
Originally Posted by thefro526 View Post
Your drive is going to be way too fast ( > 16.5 fps) with a cimple box direct driving a 6" wheel. You'll probably have issues with current draw as well due to under-gearing.
(Ignore this if you are using a Toughbox Mini as Chris said in post #6.)
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 12-11-2011, 10:59
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
If they are frugal with weight and keep it at about 100 pounds w/ battery and bumpers like we did in '11, the Cimple boxes aren't a bad choice. The reduced weight makes it much easier to accelerate, and thus easier on the motors. The speed can be harder to control in tight spaces (probably not the best choice for most of LogoMotion), but it really helps when cruising down the field. Cross-field runs occur in about 4-5 seconds with it from stop, which can really save time
Attending: MN Duluth Regional
Unread 12-11-2011, 12:14
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Assuming you used 6" wheels (which is what the OP has), did you do an analysis to see how much faster cross-field runs from a dead stop would be* if you had more than just the CIMple box's 4.67:1 reduction?
* and less current draw, and quicker acceleration and easier control in tight spaces
Unread 15-11-2011, 01:29
roystur44's Avatar
roystur44 roystur44 is offline
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
roystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond repute
Send a message via Yahoo to roystur44
If you added two more c channels to the outside of the frame, lose the internal brackets and tied the channels into the front and back channels with some L brackets you have have a nice stiff frame.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 15-11-2011, 07:40
Da' Rule Man
AKA: Nik Shepherd
Isn't it a 2-wheel design with 4 support wheels? I mean, 6 wheels, but only 2 drive wheels? Right?
Unread 15-11-2011, 09:07
Ether's Avatar
Rookie Year: 1969
The front and rear wheels are also driven, via chain.
Unread 15-11-2011, 09:51
Da' Rule Man
AKA: Nik Shepherd
Ah, gotcha. Thanks. Senior year, fourth year on the team, but I'm stiiiiiilll new. Well, what is school for?
