Go to Post Nothing's more memorable than giving someone a foul mouthed clown :cool: - Dave Scheck [more]
Unread 12-11-2011, 12:07
Ashley Painter's Avatar
Ashley Painter Ashley Painter is offline
FRC #3784 (Bit by Bit)
Rookie Year: 2011
Ashley Painter is an unknown quantity at this point
Check lists and debuging lists needed
Hey,
Team 3784 realized when we went to CowTown that there were a lot of little things that impared our performance. We're making check lists for everything from packing and tools needed to debugging and troubleshooting.
Where could we find samples of other teams' lists?
Thanks
Ashley Painter
Team Captain
FRC Team 3784
2011 Highest Seeded Rookie
2011 Gracious Professionalism
2011 Kansas City Champions
2011 ISEF Finalist
FRC Team 3784
2012 Kansas City Champions
Unread 12-11-2011, 18:27
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: Check lists and debuging lists needed
Nice set of street creds there
I'll comment on the pit list, we look at all the things that have wear and tear and build a check list based on that. We then look at the "oh, so that's why the robot didn't move last match" and put them on the list. The list is posted in the pits so it's a constant reminder what to do.
The list is in order of time. For example if the wheels need treads, that takes lots of time, so it's early in the list. Last on the list is things that may be a problem but quick to check. For example, did the programming team load new code? Then is the ethernet cable to the Wifi plugged back into the CRio?
Last thing on the list is a check of the list. Read the list out loud and wait for a crew member to yell "Done". We've had times where that didn't happen and there were failures in the match.
Learn the list, work the list, love the list.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 12-11-2011, 23:50
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
It is also important for the drive team to have a check list for queing and on the field. This can include things such as, checking the ethernet to the crio, checking that the correct autonomous mode is set, checking the minibot is on, checking the pressure gauge is closed, etc.
www.sharkattack744.com
Unread 13-11-2011, 08:51
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Always debug moving from mechanics to code.
For example, if you have a limping drivetrain, you check the wheels, then the chain, then the gearbox, then the motors, then the encoders, then the victors, then the power distribution board, then the digital sidecar, then the cRIO, and lastly the code.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 13-11-2011, 13:53
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Searching for checklist found this recent thread with a lot of good information: http://www.chiefdelphi.com/forums/sh...ight=checklist
