Our c-rio is toast! Is there a warranty?
At our last off season event our poor c-rio died right after a match. We have tried to revive it but alas, it dosent work. The team and I are now curious if it has a warranty on it, it is one year old and seems to have something loose on the inside. Can we have it replaced or do we need to buy another for next year? If we can have a replacement sent who do we contact and when can we expect a response?
Re: Our c-rio is toast! Is there a warranty?
There is a chance the internal fuse blew. http://www.chiefdelphi.com/forums/sh...ad.php?t=97620
How have you tried to revive it?
Have you cleaned out any loose metal dust, shards, or those curlicues we get from drilling aluminum over delicate electronics? Last edited by Mark McLeod : 14-11-2011 at 21:47. |
I would give them a call. The technical help number listed on NI.com is (800) 531-5066.
I saw you guys replacing the cRio at RR, what match caused it? Did anything significant happen during the match?
We managed to have someone spill pop on one of ours....NI replaced it free of charge
cRIO Systems are covered by a 3-year warranty from the day the unit shipped from our factory. For units shipped to teams as part of the 2009 KOP, the warranty technically expired (since those units shipped in August through October 2008 to FIRST). However we extended the warranty through the end of 2011 as a grace for those units. Short story - all cRIO's are still under warranty (for things covered by warranty). The KOP units from 2009 fall out of warranty on Jan 1, 2012. |
Chris,
internal fuses seem to be the common method of failure on the compact rios. After they fall out of warranty what will be the policy/cost on these internal fuses and their replacement? |
#10
![]() Quote:
I understand that this may not be seen as desirable in all cases, and we're looking at some options to ease the pain. For example, by extending the warranty period. |
#11
Ahh, that makes sense.
Thanks for all you do for FIRST. |
#12
It would probably be faster to call the NI FRC line (866) 511-6285. This was also posted in the thread that Trent linked to.
#13
There's a very good chance it is the internal fuse. Ours blew in 2010 and many others have also. Give NI a call at the number provided in this thread. They repaired ours for free and probably will for you too.
