Go to Post Mmmmmmmm. Donuts! - Sean Schuff [more]
Go Back   Chief Delphi > Technical > Control System > Sensors
Unread 16-11-2011, 15:08
MichaelBick MichaelBick is online now
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
Gyros and Field Centric Control
Our team is looking to implement field centric control on last year's robot during the preseason. I was wondering which gyros other teams have used in the past and your experiences with them. Thank you so much.
Unread 16-11-2011, 15:21
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Gyros and Field Centric Control
http://www.chiefdelphi.com/forums/sh...8&postcount=40
Unread 17-11-2011, 19:54
Rookie Year: 2010
Thank you so much.
Unread 18-11-2011, 10:58
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
Ether has pointed you in a good direction. To elaborate, you need to select a gyro with sufficient degrees/second response. A good minimum is 300. If your robot can turn faster or be struck and spun faster than the gyro can respond, your field centric controls will lose their bearing. There are several gyros available from Sparkfun with the correct input voltage. If you use a gyro that is close to your turn rate, you can always program a gyro reset into your operators controls. If the robot drifts off axis, the driver can manually position the robot back to a bearing of zero and hit a button to reset your bearing variable to zero as well.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 19-11-2011, 16:34
Rookie Year: 2010
Also, I was wondering if any teams use accelerometers on their robots. Do you have any recommendations for some that work with the wpilib library?
Unread 20-11-2011, 20:05
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Field-centric control would be a lot easier if you weren't hungry all the time. Your search for gyros is definitely a good first step.
Unread 20-11-2011, 20:43
Ether's Avatar
Rookie Year: 1969
Whatcha smokin ?
Unread 13-01-2012, 01:18
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
FYI, integrating angular rate for any amount of time is going to get very drifty - especially if you get knocked by another robot. A gyro with a high rotational limit and a very high sampling rate are both decent ways around this, but they can't get rid of bias errors and non-smooth motion issues. One way to decrease drift is to do sensor fusion with wheel encoders - using something like a complementary filter can make one system more depended-upon during high rates of rotation, and the other more depended-upon during low rates of rotation. Far better, however, is to use some part of the field that the robot can localize to - in an extreme case, you might be able to use a compass module to find direction (but the hard-iron fields will probably render one useless), or perhaps using the camera for visual servoing. I'd personally recommend the latter - fixate on the targets and keep it always in frame.
Hope this is useful
Sparks
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
Unread 13-01-2012, 06:50
Ether's Avatar
Rookie Year: 1969
Many teams simply put a button on the joystick that the driver can push to re-zero the gyro when the bot is pointed in the desired direction.
Unread 13-01-2012, 14:37
Sparks333's Avatar
Robotics Engineer
AKA: Dane B.
That works too.
