Go to Post What else could you do with a t-shirt? Wait... never mind... I retract my previous statement and realized this is FIRST and we can do anything with anything. ;) - Jeremiah Johnson [more]
Go Back   Chief Delphi > Technical > CAD
Unread 17-11-2011, 01:44
marley4070's Avatar
marley4070 marley4070 is offline
The Guitar Kidd
FRC #2439 (Bearbotics)
Team Role: CAD
Rookie Year: 2011
marley4070 is an unknown quantity at this point
CAD problems
So I've been working on AutoCAD 2011 and I've encountered a few problems.
1. When importing/inserting new blocks to a current project the blocks come out half size.
2. I changed my units from centimeters to inches in a 3 dimensional drawing, but when dimensioning, the units still appeared as centimeters. eg. a c-channel measuring 70 centimeters still appeared as 70 centimeters after changing the units to inches.
Any information or solutions regarding these problems is greatly appreciated.
-Marley
Unread 17-11-2011, 07:59
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: CAD problems
Marley,
Autocad gives you an incredible amount of flexibility to automate certain tasks and to set defaults for just about anything you can do.
For the insertion, you likely have the insert variable set to 0.5 for the insertion scale or the original part was drawn half scale. Just watch the prompts on the screen and see what the default is. If you just hit return, Acad will accept the default.
For dimensioning, you have to set the units within the dimension style dialog. This is where you can change the font of the dimension text, scale factors, arrows and offsets for the dimension lines, etc.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 20-11-2011, 16:50
marley4070's Avatar
The Guitar Kidd
Team Role: CAD
Rookie Year: 2011
Re: CAD problems
Thanks! I'm not used to using 2011 just yet. I started using the 2004 version of CAD and just upgraded to 2011, the differences between the two versions are insane. I really appreciate the help. I have a manual but I haven't gone through it to much extent yet. I'm hoping to get more acquainted with the program.
Again, thank you, I really appreciate the help.
Unread 27-01-2012, 10:44
team1512's Avatar
team1512 team1512 is offline
FRC #1512
team1512 is an unknown quantity at this point
Re: CAD problems
We have been having trouble opening the .stp, .asm and .15 files that we got from here:
http://www.catalogds.com/db/service?d=first&c=browse
We ttrie opening them in google sketchup, adn then AutoDesk Inventor PRO, but no such luck either place. Any suggestions?
-1512
Unread 27-01-2012, 12:23
skotmorris's Avatar
skotmorris skotmorris is offline
Windchill Product Manager
FRC #4909 (Bionics - Billerica Memorial High School)
skotmorris is an unknown quantity at this point
Re: CAD problems
You need to download the CAD files from Autodesk if you intend to use them in Inventor. These models are from PTC and will only work with Creo Elements/Pro 5.0 or Creo 1.0.
-Scott
Unread 27-01-2012, 12:41
kcd-adskmfg kcd-adskmfg is offline
AKA: Kim Campbell-Djuric
Rookie Year: 2011
kcd-adskmfg is on a distinguished road
Re: CAD problems
Team 1512,
You can find all of the parts for FRC 2012 for Autodesk Inventor Professional at http://students.autodesk.com/?nd=kitofparts_view
There are also parts from 2011 and 2010 formats in the parts library.
I know that you are working with AutoCAD right now but please remember that you can get Autodesk Inventor Professional 2010, 2011 or 2012 free as a FIRST team member.
We are also offering free Inventor training materials for all these versions through our partner, 4DLearning which may help get you moving on the new user interface. http://students.autodesk.com/?nd=cadlearning
Hopefully this will help you and your team moving forward.
Kim Campbell-Djuric
Autodesk, Inc.
