Physics Quiz 2
This is a continuation of the Physics Quiz posted here yesterday. The weight of the motor+wheel assembly is W. The coefficient of static friction between the wheel and floor is mu_s. How much motor torque "tau_s" is required to start the wheel rotating? |
Re: Physics Quiz 2
we know that when the system is static the force that the wheel exerts on the surface is F = τ/(rsinθ). The minimum force for the wheel to start spinning is F = τ/(rsinθ) > W*mu_s.
and so we get tau_s > W*mu_s*r*sinθ |
Re: Physics Quiz 2
F of friction = μmg which is equal to the F in τ=rFsinθ and mg = W
tau_s = r*mu_s*W*sinθ But as SavtaKenneth said, it has to be greater than in order to overcome static friction. |
Re: Physics Quiz 2
Re: Physics Quiz 2
As θ increases toward 90 degrees, the required motor torque steadily increases. Think of a skid-steer vehicle with a long wheelbase. |
Re: Physics Quiz 2
I like where this is headed.
FYI: In order for the weight to interact with the ground under the wheel and not via a reaction at the "frictionless pivot" (assumed to be a revolute joint) it must instead be a cylindrical joint. Otherwise the normal force is indeterminate (as it can have any pre-load or none at all). |
