Go to Post Pushing match, what pushing match? If they can't catch you they can't push you around. - IndySam [more]
Unread 19-11-2011, 12:43
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Physics Quiz 3
This is a continuation of the Physics Quiz posted here yesterday:
The problem is changed as follows:
- The wheel is rotating about its axis at a constant rate omega_w
- The (constant) torque exerted on the wheel by the motor is tau_k
- The wheel+motor assembly is revolving CCW around the pivot at a constant rate omega_p
- The length of the connecting rod is L
- The weight of the wheel+motor assembly is W
- The coefficient of kinetic friction between wheel and floor is mu_k
What is the magnitude and direction of the floor's friction force on the wheel?
