Go to Post Thank you NASA (except for Dave, his tormenting hints make us even) - Mike Schroeder [more]
Unread 20-11-2011, 16:06
rudun's Avatar
rudun rudun is online now
FRC #0496 (Royals)
Team Role: Coach
rudun is an unknown quantity at this point
extending CANJaguar subclass
I am trying to add methods to help with reading our robots actual speed off of a CANJaguar in fps. The issue I am having now is that it is not building becasue it needs a constructor, but if I am inheriting the class shouldn't they already exist. What i want to be able to do is when i call a CANJaguar object, e.g. leftMotor.getFps(), it will return the fps data to me. This is my code so far.
Any help is greatly appreciated.
Code:
 * To change this template, choose Tools | Templates
 * and open the template in the editor.
package edu.wpi.first.wpilibj;
import edu.wpi.first.wpilibj.can.CANTimeoutException;
import edu.wpi.first.wpilibj.can.JaguarCANProtocol;
 * @author rudun
public class fps extends CANJaguar {
    final static double PI = Math.PI;
    private double WheelSize;
     * Get the speed of your robot.
     * @return The speed of the robot in fps.
    public double getFps() throws CANTimeoutException {
        byte[] dataBuffer = new byte[8];
        byte dataSize;
        double rpms;
        dataSize = getTransaction(JaguarCANProtocol.LM_API_STATUS_SPD, dataBuffer);
        if (dataSize == 4) {
            rpms = unpackFXP16_16(dataBuffer);
        } else {
            rpms = 0.0;
        double fps = 0;
        fps = (rpms *(WheelSize * PI))/(60 * 12);
        return fps;
    public void setWheelSize(double WheelSizeInInches) {
        WheelSize = WheelSizeInInches;
and this is my current compiler output
Code:
init:
clean:
init:
clean:
Created dir: C:\Users\kyle\Documents\NetBeansProjects\fpstest\build
Compiling 2 source files to C:\Users\kyle\Documents\NetBeansProjects\fpstest\build
C:\Users\kyle\Documents\NetBeansProjects\fpstest\src\edu\wpi\first\wpilibj\fps.java:13: error: no suitable constructor found for CANJaguar()
    constructor CANJaguar.CANJaguar(int,ControlMode) is not applicable
      (actual and formal argument lists differ in length)
    constructor CANJaguar.CANJaguar(int) is not applicable
1 error
C:\Users\kyle\sunspotfrcsdk\ant\compile.xml:48: Compile failed; see the compiler error output for details.
BUILD FAILED (total time: 8 seconds)
