Go to Post the FIRST season is never over . . it just pauses a while so you can get some sleep. - Stuart [more]
  #16   Spotlight this post!
Unread 05-12-2011, 14:56
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Use/Conversion of Cypress Output Values
You need to make any and all controls changes the permanent default by clicking on:
Edit -> Make Current Values Default
You can also click on individual controls and make just one or a couple change, instead of all of them.
That's so you can play all you want with the controls, but you won't destroy the original settings until you really want to.
  #17   Spotlight this post!
Unread 05-12-2011, 15:16
plnyyanks's Avatar
plnyyanks plnyyanks is offline
Data wins arguments.
AKA: Phil Lopreiato
FRC #1124 (The ÜberBots), FRC #2900 (The Mighty Penguins)
Rookie Year: 2010
plnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond repute
Originally Posted by kws4000 View Post
Okay, now I have a realitively big issue that is not stopping me any, but may be an issue in the future.
In the Teleop VI, with the Set Enhanced Digital Config VI, with the Enum Cluster pulled out as a control to the Front Panel of the Teleop VI, the values continioulsy reset after I close the Teleop VI after I am done with it.
Is this an error with LV, or something hardwired in the Set Config VI that I don't want to mess around with?
If I understand you correctly, that's a problem with the default value of the cluster. Set the cluster to have the values you want it to retain, then right click on it and under Data Operations, choose Make Current Value Default. LV should then retain that data for the cluster.
Phil Lopreiato - "It's a hardware problem"
Team 1124 (2010 - 2013), Team 1418 (2014), Team 2900 (2016)
FRC Notebook The Blue Alliance for Android
  #18   Spotlight this post!
Unread 07-12-2011, 11:58
kws4000's Avatar
kws4000 kws4000 is offline
Team Mentor - Programming
AKA: Krazy Karl
FRC #2405 (Divided by Zero)
kws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the rough
Thumbs up Re: Use/Conversion of Cypress Output Values
And my Qs are A'ed.
Thanks, sanity has (almost) been restored!
If only there was such a clear-cut answer for game hints.....
Mentoring:
1) Educating students on the ability to learn and have fun at the same time.
2) Giving back to those who made you who you are.
2009-2011 Student 2405 Electrical/Programming & Asst. Captain
2012-???? Mentor 2405 Programming/Jack-of-all-Trades
