Go to Post Archimedes brings all the bots to the yard! - looneylin [more]
Go Back   Chief Delphi > Announcements
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Unread 22-11-2011, 09:50
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Rookie Year: 1998
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
Battery Beak
  • Tired of guessing which battery is the best seconds before a match starts?
  • Ever have a battery test at full capacity at the beginning of the season only to have it die at the start of a match?
  • Looking for a battery tester that is compact, portable and provides instant results?
If yes then the Battery Beak is what you are looking for. The Battery Beak is a battery health analyzer designed for use with the Lead Acid Batteries used in FRC and the NiMH batteries used in VEX Robotics.
The Beak provides information about a batteries State of Charge, Load Voltage, Internal Resistance and battery quality in less than a second.
The Battery Beak is new and available from Cross the Road Electronics, LLC.
www.crosstheroadelectronics.com
Unread 22-11-2011, 09:58
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Battery Beak
http://www.chiefdelphi.com/forums/sh...3&postcount=12
Unread 22-11-2011, 10:26
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Re: Battery Beak
I am very excited that this is available, and will surely be purchasing (at least) one!
However, is there a way you could shrink the images on the portal page just a little bit? It is sort of squishing the recent posts area and making it difficult to read, even on my widescreen display.
Unread 22-11-2011, 15:24
Aren Siekmeier's Avatar
Aren Siekmeier Aren Siekmeier is offline
on walkabout
FRC #2175 (The Fighting Calculators)
Aren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond repute
Re: Battery Beak
Seconded (both comments).
Unread 26-11-2011, 10:28
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Battery Beak
Originally Posted by Ether View Post
The web site states that it uses internal resistance.
The auto industry has been using internal resistance for battery health (but not state of charge) for many years. In general, the higher the internal resistance, the worse the condition of the battery. You must properly characterize the battery (chemistry, capacity) for this to work properly.
The screen display shows three voltage readings at different current values, I speculate that this is used in addition to internal resistance to measure battery condition. This is an even older (and some say more accurate) method for battery condition. In the auto industry, it is (or was) common to have a carbon pile load to test batteries, rule of thumb was 3x the Ah rating in amps, check the voltage at 15 seconds.
I will also speculate that state of charge is calculated by measuring open circuit voltage after a small load (like 18A for 10 seconds) is used to remove any possible surface charge.
Assuming the designer knew what she was doing, using these three methods (none of which are technically challenging) should produce repeatable results that are accurate enough for our purposes.
Unread 22-11-2011, 21:17
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Re: Battery Beak
[/center]
I searched and searched, but found no where to actually purchase it! I know Cross the Road Electronics markets through AndyMark, but nothing there either.
So, where and when can it be purchased?
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 22-11-2011, 23:26
Andrew Lawrence
Posts: n/a
Re: Battery Beak
I'm no electrical guy, so I don't know what this is competing against, but is this good? Is it worth the money, and how much would someone recommend getting this?
Thanks!
Unread 22-11-2011, 23:29
Andrew Schreiber Andrew Schreiber is offline
Data Nerd
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
Re: Battery Beak
Thanks!
I don't know the market for battery testers but I know the CTR guys, they release products when they are ready and not before.
Unread 22-11-2011, 23:34
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Re: Battery Beak
Our team has held off on buying a battery tester and we are pretty excited to buy this guy.
Mike, would you happen to have a video demo?
-RC
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 23-11-2011, 07:34
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: Battery Beak
No video yet but I should have a user manual posted this week or the beginning of next week. Also Andymark will also be distributing these starting in December. In the mean time they may be purchased from the CTRE site http://www.crosstheroadelectronics.com/Beak.html , I should have an "Add to Cart" link up some time today.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 23-11-2011, 12:10
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: Battery Beak
Just ordered mine, hope to have it next week to go through our VEX battery sets before the big 3 December event.
I saw this at IRI and wanted one then, I'm very happy to see that Mike was able to turn these around through manufacturing so quick.
I'm also very happy that he took my suggestion to add a mode for the 7.2 volt VEX battery packs, this will end the "is it charged or not" at our events.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 23-11-2011, 18:39
Tom Bottiglieri Tom Bottiglieri is offline
Custom User Title
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
Send a message via AIM to Tom Bottiglieri
Re: Battery Beak
This is a great idea! Seriously, every team should have one of these.
Team 254 | San Jose, CA | Mentor (2010 - Present)
Team 125 | Boston, MA | College Student (2007 - 2011)
Team 195 | Southington, CT | Student (2002 - 2006)
Unread 23-11-2011, 22:48
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
Re: Battery Beak
2012 KOP Item...? (A guy can dream)
Looks like we'll be getting one of these to test our batteries pretty soon. I'm really tired of being given a battery that 'says' it's charged and finding out that it's half dead after autonomous mode...
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 24-11-2011, 20:40
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
Re: Battery Beak
How much are they ?
  #15   Spotlight this post!
Unread 24-11-2011, 20:45
Ether's Avatar
Rookie Year: 1969
Re: Battery Beak
Originally Posted by de_ View Post
How much are they ?
Click on the "Battery Beak" link in the original post.
