Go to Post Be kind to you mentors. They are exhausted and you need them. - MrJohnston [more]
Unread 22-11-2011, 13:47
2992_daniel 2992_daniel is offline
FRC #2992
2992_daniel is an unknown quantity at this point
Held
We have been trying to develop a mecanum drive robot. So far, the robot rejects the code or takes it in and ignore it. According to our driver station, we have no code but have communications. I've attached our current code that we have built and downloaded to the robot. We are open to all kinds of helpful comments.
Thanks,
Daniel, team 2992 programmer
Unread 22-11-2011, 17:25
jwakeman jwakeman is offline
FRC #0063 (Red Barons)
Rookie Year: 2010
jwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nice
Re: Held
It sounds like the code is crashing. I see you have print statements in your code. Are you running the NetConsole? What do you see in the console?
Unread 23-11-2011, 10:36
FRC #2992
Re: Held
We are not using the NetConsole. All we receive in response is that the robot has no code on it. However, we can download and retrieve code that we send to it. Yet, it builds fine on Windriver.
Unread 23-11-2011, 15:58
Rookie Year: 2010
Re: Held
From your description it sounds like you can build the code and deploy it. It sounds like the code is running into some sort of run-time exception (probably a memory fault) and exiting which is why it says "no robot code".
The easiest way to figure out your problem is going to be to enable the NetConsole. You will be able to watch the OS boot up and you will see something printed to the console if your code is indeed crashing. To solve the crash you probably want to comment out everything and get to a point where the code runs. Then starting adding things back one at a time until you find the issue. Also add a bunch of print statements so you can trace the execution of the code. Good luck!
Unread 24-11-2011, 10:52
FRC #2992
Re: Held
Thanks for the help! I will try to get the NetConsole up and running for the robot. I will post later if I need some more help with it.
Unread 30-11-2011, 16:57
FRC #2992
Re: Held
We are having trouble with the same issue. We also need help setting up the NetConsole, could you point us in the right direction?
Unread 30-11-2011, 17:34
plnyyanks's Avatar
plnyyanks plnyyanks is offline
Data wins arguments.
AKA: Phil Lopreiato
FRC #1124 (The ÜberBots), FRC #2900 (The Mighty Penguins)
Rookie Year: 2010
plnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond repute
Re: Held
Use the cRIO imaging tool to enable NetConsole. Then re-deploy your code and open NetConsole (Start->Programs->NetConsole for cRIO).
Phil Lopreiato - "It's a hardware problem"
Team 1124 (2010 - 2013), Team 1418 (2014), Team 2900 (2016)
FRC Notebook The Blue Alliance for Android
