Go to Post FIRST is a life lesson on steroids. - JohnBoucher [more]
Unread 26-11-2011, 16:35
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
free C compiler for Windows
Hello C gurus.
Do you know if there's a free C compiler for Windows XP which has support for RS232 access, and has a sleep() function which blocks waiting (as opposed to busy waiting).
Unread 26-11-2011, 18:24
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Re: free C compiler for Windows
Not quite what you are looking for, but pyserial for python can toggle the RTS pin, if that is what you are still trying to do.
Unread 26-11-2011, 18:58
Ether's Avatar
Rookie Year: 1969
Thanks.
It's not just toggling the RTS pin that I'm after. I know how to do that.
I've written countless interrupt-driven RS232 comm test equipment apps, mostly in assembly, for older machines running DOS (where you can diddle directly with the hardware). Many of them run fine from a windows command prompt.
What I want to do is write a small 32-bit windows app that looks something like this:
void main(void){
while(1) do{
SetRTS();
sleep(10);
ClearRTS();
sleep(10);
... where the sleep() function is blocked waiting, not spinning.
I want to slap a scope on the RTS pin and watch it while I play around with Windows to see what it does to the signal under various conditions.
I'm thinking this would be a visually captivating show-and-tell for students just learning about realtime issues and concurrent processing.
Unread 26-11-2011, 22:11
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
The Windows API for serial communication has a function (EscapeCommFunction) which can be requested to clear or set RTS state.
http://msdn.microsoft.com/en-us/libr...=vs.85%29.aspx
Thus, any compiler which links to the Windows API can use it.....
I've used the VC++ compiler before (on windows), and Cygwin when building from my Linux machine. VC++ Express and Cygwin are both free. winapi also has a Sleep() function. The MSDN page on Sleep() has more information.
Kettering Motorsports
Unread 26-11-2011, 22:21
plnyyanks's Avatar
plnyyanks plnyyanks is offline
Data wins arguments.
AKA: Phil Lopreiato
FRC #1124 (The ÜberBots), FRC #2900 (The Mighty Penguins)
Rookie Year: 2010
plnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond repute
http://msdn.microsoft.com/en-us/libr...(v=vs.85).aspx
When I program C(++) on Windows, I use either Bloodshed Dev-C++ or VSC++. Both support the winapi and both are free.
Phil Lopreiato - "It's a hardware problem"
Team 1124 (2010 - 2013), Team 1418 (2014), Team 2900 (2016)
FRC Notebook The Blue Alliance for Android
Unread 26-11-2011, 23:11
Ether's Avatar
Rookie Year: 1969
@apalrd,plnyyanks: Thanks guys. This appears to be what I'm looking for.
Unread 27-11-2011, 11:26
jwakeman jwakeman is offline
FRC #0063 (Red Barons)
Rookie Year: 2010
jwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nice
I would recommend MinGW, Minimalist GNU for Windows, http://www.mingw.org/.
