Go to Post "The secret to success is to acknowledge that you have limits, but to never acknowledge that you have reached those limits." - lady_raidan [more]
Unread 29-11-2011, 19:19
inou8it inou8it is offline
Captain/Founder/Student
Team Role: Leadership
Rookie Year: 2011
inou8it has a spectacular aura aboutinou8it has a spectacular aura about
Battery Dropped?
ID:	11134Click image for larger version
Is this battery still usable and safe? It was dropped.
Unread 29-11-2011, 19:40
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Battery Dropped?
No, and No. I would have it recycled immediately. There is definite internal damage, and if the plate separators fail, you have a shorted cell, which may overheat.
It is not safe to have that battery around.
Unread 29-11-2011, 20:15
avanboekel's Avatar
avanboekel avanboekel is offline
AKA: Adam Van Boekel
FRC #5934 (Gear it Forward, Crowbotics)
Rookie Year: 2010
avanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant future
Agreed, better safe than sorry with this kind of stuff.
2338 Gear It Forward | Student 2010-2013 | Mentor 2014-Present | oswegofirst.org
2013 Wisconsin Regional Winner (1732, 111, 2338)
2013 Midwest Regional Dean's List Finalist
2015 Midwest Regional Chairman's Award Winner
2015 Archimedes Subdivision Winner (1023, 2338, 3996, 1089)
2016 Midwest Regional Chairman's Award Winner
4096 CTRL-Z | Mentor 2014 | team4096.org
5934 Crowbotics | Mentor 2016-Present | crowbotics.org
Unread 30-11-2011, 08:10
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
inou8it,
This is one of the worst fall induced damages I have seen. I would take that battery to a recycler ASAP. As other have pointed out, the internal plates on that cell are near short and when that occurs, high heat and possible case failure will result. If you think you can safely discharge the battery prior to handling, I would recommend that. If you can connect it to an auto headlight until the battery is dead, you will have less chance for further case damage and acid spill.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 30-11-2011, 13:56
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
That is definitely a no-go, get rid of it. My team had an issue with a battery 5 (wow it's 5 years already?) years ago, we noticed that one of our bateries was unnaturally warm. It started swelling at the sides, and we immediately decided this was a potential hazzard. We put it outside in a snow pile away from buildings, and by the end of the meeting it had melted a 3' radius in the snow. This was with the old style bateries, but regardless, you don't take chances with chemicals. Get rid of it! (recycled, of course)
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
Unread 30-11-2011, 18:39
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Wow. That is really cool. Scary to think what would have happened if you kept it, but still cool.
Unread 30-11-2011, 22:16
Unsung FIRST Hero
Rookie Year: 1996
Matt,
When the battery swells unchecked (like not putting it in the snow) the case seams usually come apart and the battery acid oozes out. If the temperature rises very rapidly, a far more violent case failure will occur. Regardless, the battery uses sulfuric acid. While this is somewhat diluted (typically about 30% acid) getting in your eyes nose or mouth (or other sensitive areas) will not be something you are likely to forget. If you get acid on your clothes, you may not notice a problem until after they are washed. Many fabrics will dissolve where they are touched by the acid.
In this particular case, only one cell will likely suffer from the damage, the one closest to the corner. If that cell swells internally, it may push against the plates in the next cell and cause a short there.
Al
WB9UVJ
www.wildstang.org
Unread 01-12-2011, 00:41
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
hmmm... How many batteries would it take to clear a Minnesota driveway in January?
Unread 01-12-2011, 01:02
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
Well, you could just use a large weather-proof heating element, but then again, the runoff could seep under your drive way, lawn, foundation, etc., refreeze (and expand), and cause much harder to fix issues than snow or ice above the ground...
or maybe not: http://www.heatizon.com/
Unread 01-12-2011, 07:26
Unsung FIRST Hero
Rookie Year: 1996
It would only be good enough to actually find the driveway under the snow. The rest is up to you!
Al
WB9UVJ
www.wildstang.org
