Go to Post Gracious Professionalism does not take a holiday. - JaneYoung [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
  #241   Spotlight this post!
Unread 06-12-2011, 19:04
CNettles11's Avatar
CNettles11 CNettles11 is offline
AKA: Chris Nettles
FRC #3502 (Octo-Pi-Rates)
Rookie Year: 2011
CNettles11 is a jewel in the roughCNettles11 is a jewel in the roughCNettles11 is a jewel in the roughCNettles11 is a jewel in the rough
Re: First Official 2012 Game Hint
Originally Posted by jgw View Post
1972 to the present is a bit more than 20 years!
You mean that 10 years ago doesn't mean early 90's?
  #242   Spotlight this post!
Unread 06-12-2011, 19:17
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
Im seeing an infared photoswitch, this has the capability to tell if something has interupted the beam in light of dark environments. Why would FIRST order so many photoswitches just to do the job of a ref and look for a robot passing a line? They wouldn't.
I could see a part of the field being obstucted from view.
  #243   Spotlight this post!
Unread 06-12-2011, 19:18
CNettles11's Avatar
AKA: Chris Nettles
Rookie Year: 2011
Originally Posted by Sean Raia View Post
I have just been informed that the game is called Bowled Over, appearantly there was a leak on andymark. More info to come.
Bowled over is the FTC game, not the FRC game.
  #244   Spotlight this post!
Unread 06-12-2011, 20:46
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Originally Posted by rcmolloy View Post
... a bottleneck effect like in 2010.
How about the bottlenecks in Aim High? Pokey-pokey stick anyone?
(since 2004)
  #245   Spotlight this post!
Unread 06-12-2011, 21:04
Sean Raia's Avatar
Ahh I realized that just after i hit post. I stand firm on my obstructed view prediction.
  #246   Spotlight this post!
Unread 06-12-2011, 21:21
CNettles11's Avatar
AKA: Chris Nettles
Rookie Year: 2011
4 pound bowling balls are just dense styrofoam (Think about AndyMark's battery packing foam) wrapped in a plastic shell. Those seem like the best reason for the heavy game pieces. I'd love to have a bowling game! I still think that the way that FRC is trying to tie into FTC, it could possibly involve balls being used to knock things over.
  #247   Spotlight this post!
Unread 06-12-2011, 21:22
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
I had mentioned this to AdamHeard yesterday. However, multiple items can be scored but have to eventually pass through the photosensors one at a time. It is very possible that this could be achieved with a bottleneck effect like in 2010. The only downside is there may be a jammage of game pieces.
I tried to find a picture of a 2006 low goal but was unable to. If memory serves me, the goal had 2-3 tunnel like structures for balls to go through, each with it's own photo sensor. Don't think I ever saw one jam up, even when 20-ish balls were dumped in at once.
2010's goals were never designed for multiple game pieces to pass through, or at least I don't think they were. It doesn't help that the memory foam made it really easy to jam two balls into the goal pretty tightly.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
  #248   Spotlight this post!
Unread 06-12-2011, 21:29
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Single chute with a vision sensor of some form. No jamming, but you had to clear the holding pen before the balls got stuck on the sensor, otherwise they'd count again and again.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
  #249   Spotlight this post!
Unread 06-12-2011, 21:33
Andrew Lawrence
Posts: n/a
And that's a bad thing to keep counting scores?
  #250   Spotlight this post!
Unread 06-12-2011, 21:39
thefro526's Avatar
Mentor for Hire.
Your opponent scored on you in 2006 (opposite of 2010). If you didn't clear the ball corral fast enough, the opponents score would keep going up.
-Dustin Benedict
  #251   Spotlight this post!
Unread 06-12-2011, 21:43
Andrew Lawrence
Posts: n/a
Oh.... :\
  #252   Spotlight this post!
Unread 06-12-2011, 21:52
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
There was a match replayed that year... in finals... because the lower goal counted 5 balls too many in automode. 4 high (12 points) versus 10 low (10 points), and 10 low won autonomous (score 15 points). Yes. This was in a regional finals match. The way the game was set up, this screwed up the entire match. After this incident and others like it, a delay to allow for the manual counters to report in was added.
It wasn't the hardware, IIRC, but the software that didn't quite work properly.
Past teams:
  #253   Spotlight this post!
Unread 06-12-2011, 22:31
FRC4ME FRC4ME is offline
FRC #0339
Rookie Year: 2007
FRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant future
Whoa...I think this is the most substantial game hint I've seen. Not a cryptic phrase or an obscure photograph, but a parts list for the field? In a plainly readable format?
This is too easy. It must be a decoy. The real game hint is obviously steganographically encoded in the image. Come on CD'ers, start cracking...
Go directly to queue. Do not pass pit.
  #254   Spotlight this post!
Unread 06-12-2011, 23:06
bhaidet's Avatar
bhaidet bhaidet is offline
FRC #0435
bhaidet is an unknown quantity at this point
Could the "Very high speed" of the counter not refer to how many times it can count in a second but its response time to a change of input? I am not sure exactly how it works, but the high speed may just mean that whatever triggers the sensor (probably photogate) is only blocking the photogate for a short time, meaning that it is small and/or moving fast.
Even launching a few balls into a goal a second is "fast" from the game prospective, but is nothing for a computer (and the parts list had LAN adapters that enabled direct IO, I believe somebody posted.) There must be some reason for FIRST to add extra circuitry between the computer and the sensor. If the network is not fast enough to register a goal with whatever sensor it is, the adding of a "quantizing" counter between them would eliminate this problem.
People said that in Aim High the counters were unreliable, does anyone know why? was it a speed-of-signal-pulse issue?
If used like this, this part seems like it would probably have been inserted as a tweak as the GDC played and tested (and figured that it wouldn't work well without it). I can see it happening.
photogate input: . . . . . . . . . . . . . . . . . . . ._____/\__________
Time the network is looking for a response (when high): ----____----____-
it would not be recorded because the pulse happens when the network is not listening
with the "quantizer"
signal to network: . . . . . . . . . . . . . . . . . . ._____/----\______
this time the signal and the async time the network is "looking" line up, so there will be a score detected.
  #255   Spotlight this post!
Unread 06-12-2011, 23:07
ratdude747's Avatar
ratdude747 ratdude747 is offline
Official Scorekeeper
AKA: Larry Bolan
ratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond repute
I had an idea:
what if the high speed sensors are used to monitor robots driving though lanes? like a 1-robot-per-lane version of overdrive?
just a thought...
Dean's List Semi-finalist 2010
1747 Harrison Boiler Robotics 2008-2010, 2783 Engineers of Tomorrow 2011, Event Volunteer 2012-current
DISCLAIMER: Any opinions/comments posted are solely my personal opinion and does not reflect the views/opinions of FIRST, IndianaFIRST, or any other organization.
