Go to Post The most important part of successfully solving the problem is to understand what the problem is. Elegance in engineering comes from "optimizing" your solution, not solving problems that don't really exist. Fulfill your requirements, meet your goals... - JVN [more]
Unread 02-12-2011, 10:44
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
Rookie Year: 2012
gixxy is on a distinguished road
Would any team be willing to post their Java code?
We have been looking over the FIRST Java API, and it would help greatly if another team would post their code from last year.
I understand if you don't want to, and it is alright, but if you do the programming team of 3946 would be thankful!
We started knowing almost no Java (what I knew was really from PHP and I figured out the Java variants from), and only just got the API installed, and with the build season coming up quickly it is a bit hard to work on making a sample program since we do not yet have a cRio or the DriveStation software to work with.
all help is much appreciated.
