Go to Post Well our closest regional is a Hawaii, it's a bit hard for us to drive 8000km (5000 miles) across the pacific... - timytamy [more]
Unread 08-12-2011, 22:41
whcirobotics's Avatar
whcirobotics whcirobotics is offline
FRC #1514 (Vikings)
whcirobotics is an unknown quantity at this point
CFExecute not executing appcmd.exe
created the following code on a Cofdfusion server: file name: testWebsite.cfm
This is the code:
<cfoutput>
<cfset exec_command = "add site /name:""demosite"" /bindings:http://demosite.testserver.com:80 /physicalpath:""D:\Websites\demosite"" ">
<cfexecute name="C:\Windows\System32\inetsrv\appcmd.exe" arguments="#exec_command#" timeout="60" />
Done!
</cfoutput>
But when I execute this file e.g. http://www.demoserver.com/testcases/testWebsite.cfm
It just displays "Done!" without any errors, it doesn't execute the add site code.
Upon referring numerous documents, I checked the user rights under which both execute. The coldfusion service is running as a domain user called Webserver@domain.com I don't know how to check the same for IIS. So I checked the World Wide Publishing Service and IIS Admin Service - running as Local System.
Even if I log in as the administrator, I cannot add the webserver user to the inetsrv folder or the appcmd.exe located at C:\Windows\System32
Please help with any ideas/suggestions.
Thanks.
"A team back in training !"
