Go to Post When I got home from work my facebook wall had exploded with people chanting the names of dead scientists. Did someone say culture change? :cool: - Ian Curtis [more]
Unread 10-12-2011, 11:50
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
Rookie Year: 2011
tilky is an unknown quantity at this point
keyboard in cRio project
last year, our programmer, who graduated, programmed the robot to disable if the spacebar is pressed (someone broke the stop button). I know that you can't use keyboard inputs, so how did he do this?
Unread 10-12-2011, 12:20
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: keyboard in cRio project
He didn't program it. It's built into the driver station.
Unread 10-12-2011, 16:19
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The 2010 and 2011 Driver Station software accepted the F1 key to enable the robot and the space bar to disable. Control-Alt-Enter was what the USB Stop button produced, and it was recognized as the Emergency Stop command.
For 2012, the USB Stop button is no longer used with the Driver Station, and the space bar will do the Emergency Stop. The Enter key takes its place as the disable command. It takes a little training to remember not to press the space bar to disable the robot.
Unread 10-12-2011, 17:10
plnyyanks's Avatar
plnyyanks plnyyanks is offline
Data wins arguments.
AKA: Phil Lopreiato
FRC #1124 (The ÜberBots), FRC #2900 (The Mighty Penguins)
Rookie Year: 2010
plnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond repute
That's good to know, thanks for mentioning that. For some reason, I feel we'd miss that bit of information and spend way more time that I'd like re-discovering the correct keyboard shortcuts.
Phil Lopreiato - "It's a hardware problem"
Team 1124 (2010 - 2013), Team 1418 (2014), Team 2900 (2016)
FRC Notebook The Blue Alliance for Android
Unread 12-12-2011, 07:16
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
Rookie Year: 2011
oh ok. That helps a lot. So there is no way to have it recognize other keypresses, right?
Unread 12-12-2011, 08:32
At this point, the driver station doesn't do anything with the keyboard except for the three keys mentioned:
F1 enumerates the joysticks again and tries to enable the robot
Space estops the robot, older versions disabled
Enter disables the robot, older versions did nothing
If you wish to use other keys, you can do it with the dashboard, and have the dashboard send messages to the robot. What is it you had in mind? Is it easier or better to do this with a game controller or joystick?
Greg McKaskle
Unread 13-12-2011, 07:07
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
Rookie Year: 2011
well there is nothing in mind specifically, i was just wondering in case it came up somewhere, so i had the knowledge about it. there is something that i could use it for possibly now that i think about it. How would you put it into dashboard? is it the same as a standard vi?
Unread 13-12-2011, 09:45
Omar's Avatar
Omar Omar is offline
Omar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of light
See FRCMastery.com on Dashboard Customization
http://www.frcmastery.com/labview-fo...customization/
Omar
