Go to Post Well, there goes our bare aluminum corner tracking full field navigation system... - Whippet [more]
Thread Tools Rating: Thread Rating: 6 votes, 3.67 average. Display Modes
Unread 10-12-2011, 15:41
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is offline
Coach
FRC #1086 (Blue Cheese)
Team Role: Teacher
Rookie Year: 2007
wilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond repute
[FTC]: using robotc competition template
Greetings,
This is my first year with a team that uses RobotC. We have a working Teleop and Autonomous code. How do we integrate these two files into the competiton template?
Currently: Coach FRC 1086/FTC 93
2006-2011 Coach FRC 2106/FTC 35
If you come to a FRC event to see a robot competition, you are missing the point.
Unread 10-12-2011, 17:22
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Team Role: Leadership
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Re: [FTC]: using robotc competition template
Originally Posted by wilsonmw04 View Post
Greetings,
I'm not the expert but cut and paste might be all that is needed
FTC templates
RobotC experts page
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 10-12-2011, 17:44
wilsonmw04's Avatar
Coach
Team Role: Teacher
Rookie Year: 2007
We have the templates. I have looked through the robotC and FIRST's FTC resources but I cannot find instructions on how the template is supposed to work.
Unread 10-12-2011, 21:13
Rainydaymaker's Avatar
Rainydaymaker Rainydaymaker is offline
AKA: Jim
FRC #1983 (Skunk Works)
Rainydaymaker is on a distinguished road
There is a comment that indicates where to put your code. It is just below the "wait for start". When you run your autonomous program it will execute to that point and wait for the FCS to start the game.
Jim
Coach 3721
Unread 14-12-2011, 17:12
alphadog0309's Avatar
alphadog0309 alphadog0309 is offline
AKA: Karan Hiremath
FTC #0110 (MFS Foxes)
alphadog0309 will become famous soon enoughalphadog0309 will become famous soon enough
You will have to use the RobotC Program Chooser program OR RobotC's Joystick Control- FTC window to select the tele-op program as your teleop code. This will write a text file called FTC Config.txt on your NXT and this text file will have the name of your teleop program within the file. When the FCS goes to teleop mode it will read this file and run your teleop code automatically.
You will need to run the autonomous program you chose before you start the match.
The waitForStart() command placed at the beginning of your program will ensure that the robot does not move until it receives the Go command from the FCS.
Here is a more in depth tutorial I made for some FTC teams... hope it helps! If you need any more help feel free to comment on my site there or email me at karan.hiremath@gmail.com! Good luck!
Karan Hiremath
FTC Team 110- MFS Foxes
Facebook: MFS Foxes
YouTube: MFS Foxes
Twitter:
@Foxes_110
Co-Captain
Head Programmer
Service Coordinator
Builder
Electrical
Unread 09-01-2012, 22:50
techappetite's Avatar
techappetite techappetite is offline
AKA: Titus
FRC #3528 (Up Next)
Team Role: Marketing
techappetite is on a distinguished road
Smile Re: [FTC]: using robotc competition template
You might have seen this already, but you can also use my Teleop Catalyst for RobotC program to generate the teleop code for you.
Here's a screenshot:
You can get it for free from here: http://ftc.kcastromechs.org/catalyst/
Check out Tele-op Catalyst for ROBOTC, a free program which writes tele-op/usermode programs for you!
Code:
http://tituswoo.com/project/catalyst
