Go to Post I don't like to tempt the gods of inspection on items like this. - MrRoboSteve [more]
Unread 12-12-2011, 17:12
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
Mentor / Bayou & CMP Division LRI
FRC #0456 (Siege Robotics)
ChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond repute
Honeycomb Composites?
We have traditionally used ½” SandyPly plywood for our electronics boards available from our local Home Depot. It is cheap enough, non-conductive, easy enough to work with and mount electronics to using simple wood screws, but not exactly as light as I would like. I’m looking for a better alternative this year.
I have heard various comments here on CD lately regarding the use of composites, particularly honeycomb fiberglass/aluminum/plastic panels and particularly for use as lightweight but structurally rigid panels for mounting electronics and such. While I have seen these materials on occasional robots at competition I am mostly unfamiliar with these products. For the benefit of us uninitiated in these honeycomb panel products would some of you please provide more information? Particularly, where do you get it? What sizes/thickness do you use? What are the material properties of what you have used in the past such as weight per square foot per thickness? How easy/difficult is it to work with (how do you cut/drill/machine it)? How expensive is it? How do you mount electronics to it (screws?, tape?)? What else have you found it useful for?
Unread 13-12-2011, 21:43
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud of
Re: Honeycomb Composites?
We have used Alumalite with good success. It has a plastic core with aluminum panels on both sides and is used for high-quality signs and on the sides of RV's. It comes in various thicknesses (we used 1/4 in.) and is very rigid and strong. It also looks great, cuts with typical woodworking tools, is reasonably economical (4 by 8 sheet is about $80-100 from a local sign supply company). We use small bolts, nuts and washers to mount components. It comes in various colors and can often be used for other components on your robot. Check http://www.laminatorsinc.com/sign-pa...ucts/alumalite for more information. Alumalite was used to make the trailers used on field a few years back.
We have also used corrugated polycarbonate sheets. These are extremely light weight, very tough, mostly rigid and easy to work with woodworking tools. This product is used in roofing and wall panels in greenhouses and can be purchased from your local plastics supplier. McMaster Carr also has a similar product. It comes in a variety of thicknesses. If you are mounting a lot of heavy components, I'd use 3/8" - 1/2" thickness, but light weight components can easily go on a 1/4" piece. To keep bolts from pulling out, use washers, maybe fender washers on heavy items. Again, this is not a very expensive product that will save a lot of weight. Do a search for "corrugated polycarbonate" for more information, or run over to your local plastic supplier to see it.
Dr. Bob
Unread 13-12-2011, 22:23
Andrew Lawrence
Posts: n/a
IDK what it's called, but one of our mentors works somewhere where they use these things and throw out the leftovers, so we get as much as we'd like! It's not only really sturdy, and really durable, but it's extremely light, too! Love the stuff, and I hope to use it on the 2012 bot (if applicable).
Unread 13-12-2011, 22:59
sportzkrazzy's Avatar
sportzkrazzy sportzkrazzy is offline
AKA: Zac
FRC #1592 (Bionic tigers and 801 Horse power)
Team Role: Coach
Rookie Year: 2007
sportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant future
Send a message via AIM to sportzkrazzy
If you get a chance you need to talk to IndySam about it. They use honeycombed aluminum on their FRC robots and know a lot about it. I am sure he or any of the guys from 829 would be happy to answer any questions you have on it. They are good people and always happy to help.
Unread 14-12-2011, 00:26
MichaelBick MichaelBick is offline
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
Last year we used honeycomb aluminum for our arm. While I would not recommend it for a manipulator, i think it would be a great material for almost any other use.
Unread 14-12-2011, 00:29
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
FRC #0973 (Greybots)
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
Team 1515 uses coroplast (corrugated plastic sheet, much like plastic cardboard) for E-boards. They are incredibly versatile, and can be cut with a wide range of tools. I tend to dislike Honeycomb composites primarily because of their tendency to deform. They have a fairly low shear strength, and cannot take any major hits.
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
Unread 14-12-2011, 00:40
CarlosGJ CarlosGJ is offline
FRC #0418 (Purple Haze)
Team Role: Mechanical
CarlosGJ is an unknown quantity at this point
For the past two years, team 418 has used 1/2" Kevlar honeycomb for structural panels/electronics mounting. We get it from a contact in the aerospace industry (apparently, it's the stuff used to make floors in airliners). It cuts fairly well with a circular saw, although cutting tends to generate a lot of dust: do it outside. While it is very strong and rigid, the faces are not very tough. That is, a sharp impact (say a ball-peen hammer) can crack the surface. For the same reason, we generally use large diameter washers when bolting or riveting through it.
Unread 14-12-2011, 01:47
Joe G.'s Avatar
Joe G. Joe G. is offline
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
Although I've never used it for robotics, I'd consider giving this stuff a look. It consists of two thin sheets of G10 fiberglass or carbon fiber, surrounding a honeycomb structure made of nomex. I've used it for a number of things in high power rocketry, and can confirm that it's great stuff...very rigid, and almost unbelievably light. Not something that I'd want to put in a spot way out in the open, but it can take a hit if need be.
I have cut it with both dremels and bandsaws without issue, beyond those typically associated with cutting fiberglass (be careful with the dust!).
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 14-12-2011, 07:49
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
While honeycomb materials may be good for some apps on the bot, they tend to be expensive. An alternative to the 1/2" plywood would be to take a piece of 6mm or 1/4" birch plywood and laminate a layer of 5 - 6 OZ carbon fiber to it. You'll get a very ridged and impact resistant material. We do this for our electronics board and other parts. The goal being to introduce the students to some composite construction. You could make your own honey comb stuff but it is more difficult than the plywood and carbon.
Unread 14-12-2011, 18:18
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by SuperNerd256 View Post
Just a thought: Has anyone tried or thought about making a drivetrain from this stuff? I mean, it's durable, really light, and really sturdy!
Not as durable and sturdy as you think. It's strong as a sheet, but easily damaged by impacts - something FRC bots see a lot of. However if you consider and manage that, it is something to consider.
Or use plain old Fiberglass, tons cheaper than CF and plenty strong.
Or make your own composite with thin foam (available as insulation at Home Depot/Lowes) covered with a layer of fiberglass. Just use Epoxy resin, as Polyester resin will melt the foam. Buy small quantities of foam, fiberglass and epoxy resin and give it a try.
Unread 14-12-2011, 19:06
Aidan S.'s Avatar
Aidan S. Aidan S. is offline
2013 World Champions!
FRC #0610 (The Coyotes)
Aidan S. is just really niceAidan S. is just really niceAidan S. is just really niceAidan S. is just really nice
Team 610 last year used 1/8th inch lexan for their electrical panel, and found it to be a suitable material to use. It was relatively strong and rigid, yet flexible enough to be able to take a hit without cracking. For affixing our components, we used zip ties to attach all components except the larger ones such as the cRio and Power Distribution Panel. We were also able to cut out the panel with some of the mounting holes on our CNC router very easily, which was another plus. From our experiences with the material, I would highly recommend using 1/8th inch lexan for your electrical panel.
2013 Galileo Division & World Champions with 1241 and 1477 #TheTheoryOfTexanCoyotes
2012 - ????: Mentor, Team 610 2009 - 2012: Student, Team 610
2013 - ????: Strategy Adviser, Team 1310
Thanks to all the great alliance partners through the years: 67, 188 x4, 191 x2, 488, 469, 578, 842, 862, 1212, 1241, 1305, 1310 x2, 1325, 1334, 1511, 1535, 1477, 1559 x2, 2122, 2168, 3161, 3360, 3396, 3476, 3609, 3756, 4124
Unread 14-12-2011, 00:31
Andrew Lawrence
Posts: n/a
Just a thought: Has anyone tried or thought about making a drivetrain from this stuff? I mean, it's durable, really light, and really sturdy! Plus, if you get a semi-thick sheet of it, you can just carve out the center and you have your base and everything! Cut out holes, etc. to get the wheels in, and keep anything needed to mount motors, etc.
Unread 14-12-2011, 00:39
AKA: Mathew Simon
Yes. Team 1836's 2008 robot (one of the small sprinters) was made largely of honeycomb aluminum and spacers. It was really light and incredibly fast until we lost control and hit a wall. The devastating crash required the robot to undergo design changes and rebuilding. Team 1515 used it as a trackball guide (if I remember correctly) on their 2008 robot. I don't have pictures, but it is completely bent out of shape.
Mathew Simon
CAD/Design
