Go to Post Ha, our 2009 robot's nickname was Sparky, for the same reason...we now have EXTRA fire extinguishers because of it ;P - Karibou [more]
Unread 13-12-2011, 09:22
ebarker's Avatar
ebarker ebarker is online now
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Lathes and Mills
If you wanted to spend $ 2,000 on a lathe, and $ 2,000 on a mill, what are some good recommendations. Remember to stay close to the budget numbers.
Does anyone have experience with this
or this
Ed Barker
Unread 13-12-2011, 09:28
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Team Role: Teacher
Rookie Year: 2007
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Re: Lathes and Mills
We are also looking at buying a mill and after talking to a team down the road from us they recomended one like this one
http://www.grizzly.com/products/Vertical-Mill/G3102
Mind you with tooling this would easily pass the $3000 mark.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 13-12-2011, 11:31
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
The 10K Machine Shop thread recommends a mill and a lathe around your budget. More importantly, it also shows the cost of tooling.
Unread 13-12-2011, 16:31
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
The 10K machine shop thread seems outdated as the price of the lathe has jumped dramatically and the mill doesn't seem to exist anymore.
I have heard very good things about this lathe http://www.machinetoolonline.com/PM-1127-VF.html. Supposed to be much higher quality than the average Chinese machine tool.
I have extensive personal experience with that JET lathe and it is trash (and overpriced) in my opinion. The fit and finish is very bad. It's extremely difficult to use, does not easily hold tolerances well, and has almost zero power.
You can get the machine I linked, with DRO, for only $400 more than that JET. Or the base model for less than the JET, while having power feeds on both axes, infinitely variable speed (very nice), longer travel, and much heavier duty.
I would avoid the 2 in 1 machines like the plague. you end up with two poor quality/poor usability machines instead of 1.
I know you asked for a recommendation of a mill in the $2000 range, but I will throw this out there in the off chance you can afford more.
I've posted about this machine elsewhere. We have it in our trailer that has supported many FRC events in the last 8 years. It is much higher quality than the average benchtop mill. It can take real cuts and the fit and finish is quite good. It's the only small mill I've ever used and not absolutely hated. It is more expensive than you wanted to pay, but you get what you pay for.
You will find a bunch of round column JET and other brand mills in the price range you are looking at. They will all be identical, made in the same factory in China and then rebadged/painted for each brand. They will all be relatively poor quality (though much better than the 2 in 1 you linked).
If you are locked into a budget of $2,000 then you are pretty much stuck in round column territory, unless you want to go with a smaller capacity machine like this . That's not to say you can't produce good parts with one of those machines, it's just going to be more difficult and less user friendly. I think the extra cost would be well worth it, but if you can't swing it you can't swing it.
As previously mentioned keep tooling in mind. You will likely spend at least 50% of the cost of the machine on workholding, toolholding, cutting tools, etc
2001-2004: Team 100
2006-Present: Team 254
Unread 13-12-2011, 17:32
George C's Avatar
George C George C is offline
AKA: George Chisholm
FRC #1360 (Orbit Robotics)
George C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to behold
I would check out some industrial auctions, Kijiji, Craigslist or eBay for used machines first. You'll get much better prices and many machines will come with tooling. Watch your voltages as many industrial machines run on 600V which many schools don't have. Also watch your guarding requirements as many industrial sell-offs don't have current or any safety guarding.
Unread 13-12-2011, 18:24
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
For what the G01619 costs you can do better on the used market. I'd prefer a round-column mill over that one. At home I have a machine very similar to the G3102 and it isn't bad at all. Mine is a 1970s Taiwan-made and does not have the worm drive on the quill. I picked it up for $500 used with a vise, collets, and some studs, nuts, and clamps.
Any businesses or other schools in the area closing up shop?
Unread 13-12-2011, 20:01
ebarker's Avatar
AKA: Ed Barker
Agreed on the "all in one" machines. They usually do nothing well.
The $ 2,000 isn't locked in but a reference point, something far far away from $ 500 and $ 20,000
We're looking for that sweet spot for FRC robotics.
It doesn't need to be CNC, but needs to be a lot better then hacking away with a hacksaw, drill, other random stuff in the tool box.
Ed Barker
Unread 13-12-2011, 20:38
DonRotolo's Avatar
Back to humble
FRC #0832
Another vote for the used market.
I know of a few used machinery specialists, who make a living brokering used machinery. They can get better quality machines, like a South Bend, in very good condition for well within your budget, with tooling. And, if they're a little sympathetic to your cause, often they'll let you get a nice bargain.
Surely such folks are found in your neck of the woods?
Unread 13-12-2011, 20:41
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud of
Hi Ed,
Look around some of the used machine tool companies for a good Bridgeport. Nothing works quite as well. You can probably find one in your price range with a lot of life left in it. These usually go pretty low bid on ebay because of the costs of transporting them, but you should be able to find on in the Atlanta area. With mills, the heavier, the better, since parts don't flex as much.
I imagine you will be doing mostly aluminum, which is easy to do on most mills of any size. My Burke MVN mill is a "junior Bridgeport" which does great on aluminum, without many bells and whistles. It doesn't work quite as well on steel, particularly on hard steels, but I do very little steel.
Stay away from the "neither fish nor foul" combination tools. I would only try to use on in a flat-out emergency.
For Grady, we purchased a Grizzly Mill, but I don't see it in the on-line catalog. It looks good for amedium-sized mill, but I haven't had a chance to run it yet.
Dr. Bob
Unread 14-12-2011, 10:33
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
Rookie Year: 2007
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Another vote for used machinery. We recently outfitted an entire new shop almost entirely with used equipment, and have a far better and more capable shop than if we had tried to buy new and cheap. In this economy, there is a surplus of used equipment from companies and shops that have closed or downsized. A good 'ole piece of American cast iron in usable condition will serve you better than the Chinese stuff from Grizzly or elsewhere. Find an equipment dealer in your area that deals in used equipment, and let them know what you're looking for. They will be glad for your business, and will do the legwork for you.
Unread 14-12-2011, 10:51
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Rookie Year: 2007
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
i can agree with jspatz1 100%. the shop in our school bought Chinese equipment for classes. the teacher in charge has had nothing positive to say about them once they break (which they do). we also have a old English lathe in that shop along with the Chinese and he said he's never had to fix it, where as he's constantly fixing the Chinese lathes. this is our experience. also going to auction's is another great place to look, or talking with your engineering sponsors about donating old equipment that is replaced with newer equipment is a great place to get if from because it usually still works great, is free, and is as accurate as you want it to be.
also stay away from grizzley table top lathes... i never thought i'd see the day that a lathe had plastic gears in it... they also aren't very tight, so you have to push your tooling into the piece with pressure, which usually breaks the piece at certain radii...
Unread 14-12-2011, 13:36
ebarker's Avatar
AKA: Ed Barker
Another question, which would you purchase first.
1) lathe
2) mill
Ed Barker
Unread 14-12-2011, 13:58
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Rookie Year: 2011
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Personally I would go for the mill first, and with a 4th axis it can do some lathe operations when really needed.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 14-12-2011, 14:55
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
1) lathe
2) mill
I would say that it depends on what you need. If you're in dire need of something to cut material with that isn't a hacksaw, get the mill first. Don't go for the lathe first unless you know that you're going to be working with axles/hubs/the like.
Also, is space an issue? As others have said, you may be able to get a large Bridgeport in great condition from a company or sponsor in the area, but they're difficult to transport and take up a lot of space in both height and footprint.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
  #15   Spotlight this post!
Unread 14-12-2011, 15:47
Chexposito's Avatar
AKA: Expo
FRC #1730
Rookie Year: 2007
mill first, hands down, there is so much more that a mill can do when it comes to building robots. a lathe is more of a luxury item for additional customization. you cannot have a lathe without a mill, you'll run into too many problems
