Go to Post I know the world needs more engineers, but FIRST isn't all about engineers and robots... that's why it's so great. - Ryan Dognaux [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Unread 13-12-2011, 10:47
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Rookie Year: 2011
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
pic: Team 3647 West Coast Drive
Unread 13-12-2011, 10:49
Chris is me's Avatar
AKA: Pinecone
Re: pic: Team 3647 West Coast Drive
Great job!
I bet the gussets could be 1/8" thick instead of 1/4" and still hold up.
I would add some kind of cross bracing connecting the two gearboxes together. This will make your whole frame more rigid and provide those gearboxes and CIMs with much needed support.
Unread 13-12-2011, 11:19
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Ditto Chris for the transmission support. 1/8" plate, bent at the proper angles and bolted to the front of the transmission and joining at the top of the side rails may solve it.
GitHub
Unread 13-12-2011, 11:33
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Looks like a good start!
I would seriously consider riveting a belly pan made of thin sheet (0.030" aluminum or 0.040" polycarbonate maybe) to the entire bottom of the frame and omitting the bottom gussets. This will be a nice place to mount electronics and other components as well as stiffening and strengthening the frame substantially. Ditto on making the gussets thinner also.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 13-12-2011, 11:58
Mk.32's Avatar
AKA: Mark
Rookie Year: 2011
Thanks for the feedback!
Slight updated version, bigger standoffs and nutted/bolted.
The gussets currently are 3/16, so 1/8th would hold up just as well?
And replacing the bottom gussets with a poly carb bell pan sounds like a good idea.
I am thinking of using this: http://www.andymark.com/product-p/am-0836.htm
Also I am debating between using eClips or threaded ends on the shafts to hold the wheels in place, would you would guys recommend?
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 13-12-2011, 12:11
Thad House Thad House is offline
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
One idea I would have would be to move the center sprockets to inside the transmission plates. This way the outer transmission plate could be touching the chassis which would give much more support to the gearboxes.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 13-12-2011, 13:06
Mk.32's Avatar
AKA: Mark
Rookie Year: 2011
This was something I thought about but the reason why I didn't do it was because the gearboxes are fully based on the toughboxes. If I changed the layout of the gearbox (moving the sprockets inside), it would mean we would need to make custom shafts and I want to keep machining down as much as possible.
Unread 13-12-2011, 13:21
Rookie Year: 2010
We were able to do this without making custom shafts by using the cluster shaft from a supershifter. the main output shaft works with a larger gap without any issues as long as you get the extended output shaft
Unread 13-12-2011, 13:27
Mk.32's Avatar
AKA: Mark
Rookie Year: 2011
Oh I will definitely look into that, thanks!
Unread 13-12-2011, 14:19
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
I notice that you have some rather serious looking fasteners going all the way though the transmission and frame tube. I would suggest making those fasteners smaller. Graded 1/4-20 bolts will be plenty strong enough, even graded 10-24 fasteners would work fine.
I would also suggest having either an insert in the frame tube to transmit clamping loads from the bolt, or have a clearance hole on the outside tube wall and have the bolt only clamp to the inside tube wall. Otherwise it becomes easy to bend or crush the tube with zealous tightening.
Unread 13-12-2011, 14:35
Mk.32's Avatar
AKA: Mark
Rookie Year: 2011
They are 1/2-13, I wasn't sure how well 1/4-20s would hold so I went big... but I guess it wasn't needed.
I will make the outsides holes, clearance holes in the next revision for sure.
Unread 14-12-2011, 20:24
Borobo Borobo is offline
AKA: Patrick
FRC #0159 (Alpine Robotics)
Team Role: CAD
Rookie Year: 2010
Borobo is just really niceBorobo is just really niceBorobo is just really niceBorobo is just really niceBorobo is just really nice
I do not like the look of those gussets. The fact that the frame has no internal bracing and the gussets are so small and have so few holes I think might make it really structurally weak. I would definitely increase the number of holes in each gusset and make them longer so that there is more bracing in each corner. Also, I would recommend another member somewhere in the center.
Unread 01-05-2012, 20:15
zcoops97 zcoops97 is offline
AKA: Zach Cooper
FRC #0340 (G.R.R.)
Team Role: Mechanical
Rookie Year: 2012
zcoops97 has a spectacular aura aboutzcoops97 has a spectacular aura about
Over on team 340, we had a similar concept... Andymark supershifters that worked great... had our chain runs inside 1.5 by 2 inch tubing (1/8 inch wall), easy to get to with the right pocket placement, and much, much safer... still had the 1/8 inch drop center, wedge top tread. We were pretty happy with our drive base this year
