Go to Post I think all drivers will be required to wear tights! - Mike Martus [more]
Unread 13-12-2011, 20:35
team 3311 team 3311 is offline
FRC #4057 (Klamath Basion Robotics)
Team Role: Leadership
team 3311 has a spectacular aura aboutteam 3311 has a spectacular aura about
Questions about AM super shifters
Hi my team was thinking about doing shifting transmissions this year and I wanted to get some advice about them before we go and put down a larges sum of money.
1. How do you mount them I have seen the pic. and I don't see any mounting brackets
2. what do most people use for the ratios. should we use the standard or go for a optional ratio.
3. Should my team go for servo of pneumatic shifting. Myself I would go with pneumatic but I have been wrong before,
Some background, this is my 5 year in FRC. I moved and stared a team in klamath falls OR. 3 years ago just this season our numbers have tripled. This year my team will most likely go with the kit bot on steroids,(6 wheel drive with 6'' placation wheels). We have limited machining, but we can still make parts if necessary.
If anyone needs more info I will be most glad to share it. Any other advice would be great to.
Unread 13-12-2011, 20:40
Andrew Lawrence
Posts: n/a
Re: Questions about AM super shifters
We'll also be using them this year, so here's some info I know about them.
The ratios should depend on the game. You don't want to gear for really fast if the game doesn't require a lot of speed, and likewise, you don't want to have a really slow gear if you don't need to push anything.
Personally, I'd choose the pneumatic shifting, as it allows for shifting on the fly, and can be a lot better in some situations than servos (Such as shifting while going at full speed).
We, too, plan on using 1114's Kitbot on Steroids this year, with AM SuperShifters, so if you have any questions on it, feel free to contact us or PM me!
Unread 13-12-2011, 20:48
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
I'll only answer the ones I have experience with.
The four 1/4-20 bolts that hold the box together can also be used to face mount. Otherwise, you're making your own brackets and holes.
Pneumatic leads to wasted weight if you don't have other pneumatic systems. You need at least an air tank, a relay module, valves and a solenoid in addition to the cylinders, whereas you have just the two servos in the alternate setup. You also run the (reasonably slight) risk of running out of air mid-match.
We've only used servo shifting recently because we haven't used any pneumatic systems in the last few years, and it's worked fine for us. The servos didn't break and we shifted smoothly enough. SuperNerd is right that the pneumatic shifting is faster and firmer, but I don't think that's enough reason to warrant building a whole pneumatics system just for shifting.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 13-12-2011, 20:53
AlexH AlexH is offline
Rookie Year: 2010
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
I'd go pneumatic with a spring return piston to lock it in low gear if you run out of air or have a failure in your pneumatics.
Unread 13-12-2011, 20:55
Andrew Lawrence
Posts: n/a
I forgot to mention that! Yeah, Ninja_Bait's right. Unless you're using pneumatics in other places, then I don't suggest using pneumatic shifting. While it is more on the fly, the weight used is much needed elsewhere. So unless you're already using pneumatics for a few things already, use servos. They may not be as fast, but shave a lot of your weight compared to pneumatics.
Unread 14-12-2011, 04:52
R.C.'s Avatar
Happy Birthday! R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
You could just put on a large plastic tank and just refill it before each match Pneumatic over servo shifting is preferred, but 27 has had great success with servos. Try out both, but most teams end up using pneumatics for shifting and wouldn't ever do anything else.
-RC
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 14-12-2011, 09:15
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
1) Check out this picture, it seems to be a pretty easy way to mount a Super Shifter to the C-Base or similar chassis.
Here's a shot of how we mounted our shifters this year. We took the transmission bolts and ran them through our side rail and the transmission.
2) Choosing ratios is a game based decision. Personally, I found that the standard ratio was a little slower than I liked in 2011. Would've been fine for 2010 though. On an open field you may want to gear a little faster than a closed field.
3) Pneumatic shifting is our preferred method. I've heard nothing but bad things about servo shift, and my experience with servos in FRC hasn't been the best.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 14-12-2011, 09:50
Andrew Lawrence
Posts: n/a
-RC
Have you tried this before? If so, would you recommend it? What tank have you used? Do you ever run out of air in a match?
Unread 14-12-2011, 11:36
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
Check out FRC Designs for different robots that include shifting transmissions. This website has the CAD for different transmissions and robots. You can also go to the Drives Page to see different assemblies. Let me know if you have any questions. Thanks!
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Unread 14-12-2011, 15:17
roystur44's Avatar
roystur44 roystur44 is offline
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
roystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond repute
Send a message via Yahoo to roystur44
971 uses the AM guts, makes custom plates, mods the gears and adds a hex shaft with pot attachment. If you go pneumatic make sure you tune the dog gear alignment before you do a final tighten. Always good to break in the motors and the transmission and make sure you use lots of lube on the gears.
Always check the main pinion for wear and tear. If your robot is geared fast and does high speed direction changes the pinion can have a catastrophic failure. Here is our tech note
http://www.spartanrobotics.org/conte...ed-pinion-gear
Name:	971 transmission.jpg
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 14-12-2011, 15:36
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Note that if you use AM Shifters with pneumatics, you'll want to CAD them to ensure that the pneumatic cylinders do not interfere with each other. This is especially crucial if you use the C-Base setup and direct drive the middle wheels.
If you're doing a kitbot-on-steroids setup, this isn't really a concern.
GitHub
Unread 14-12-2011, 16:55
Jared Russell's Avatar
Jared Russell Jared Russell is online now
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Or you can just use a single cylinder with 1" stroke and an extension to shift both gearboxes at the same time
(not the greatest picture, but you can see the shaft linking the piston between both gearboxes)
Unread 14-12-2011, 17:11
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
BrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond repute
We mounted our supershifters in this manner and while it was simple and easy it takes a while to take off. In the off-season we built a new robot and instead of using the two c base plates to support the trannys, we took some of the AM cross hex tube from the kit to span between using the top four bolts. Very easy and a whole lot easier to work on the drivebase!
I'd recommend pnuematic shifting over servos. If the drivebase is the only item that is using pnuematics, then a pre-filled tank is viable. Do a simple test of how many times you can shift before your compressor kicks in. You'd be surprised how few times you end up shifting in a match. This past year we shifted maybe 5-6 times per match but your needs will change based on your robot. I've heard of several teams doing this but they just end up putting the compressor on because they have the weigh to spare.
1519 Mechanical M.A.Y.H.E.M. 2008 - 2010
3467 Windham Windup 2011 - 2015
1058 PVC Pirates 2016 - xxxx
Unread 14-12-2011, 21:06
R.C.'s Avatar
Andrew,
We tried this recently and it works great. We normally pre charge our pneumatic system via an external compressor so the compressor has to do less work before each match.
On our offseason projects. We put two 44 cubic plastic tanks on there. We get around 150+ shifts via a 5/8ths od pneumatic cylinder with spring return. We normally like to have a compressor on board but if your only shifting your fine. IIRC 217 this year used hella plastic tanks and no compressor? Can someone confirm?
Thanks,
-RC
R.C.
  #15   Spotlight this post!
Unread 14-12-2011, 21:28
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
217 had 8 (visible, maybe more hidden) tanks and no onboard compressor.
They actuated their minibot deployment, claw, and shifting pneumatically.
We needed a compressor due to the air usage of the dual drive, and still ran low on air at the beginning of the season (With only 2 of the plastic tanks and the Viair mini-pump). We later added more tanks, and are currently at 6, and seem to be OK, but it takes 3 minutes to pump up.
Relating to the shift pistons, we used modified SuperShifters (same guts, new side plates, AM long shaft, spacers instead of the box) with small cylinders, to fit the battery in between the drive CIM's (vertically). We had to machine a new interface plate for the piston (we took the AM one and added more holes), and an odd stud (1/4-28 one end, #10-32 on the other) to interface with the pistons.
We had no issues with the modified SS's on the competition robot, or the stock SS's on the practice robot all season. Each robot saw many hours of use.
Kettering Motorsports
