Go to Post Smaller FRC bots...... This is what the Mayans were referring to.... My world is ending.... - CrazyHorse [more]
Unread 13-12-2011, 22:00
Matthew Blake's Avatar
Matthew Blake Matthew Blake is offline
FRC #3481 (Bronc Botz)
Matthew Blake is an unknown quantity at this point
[FTC]: FTC Ball Bearings
Are we allowed to use ball bearings in FTC?
Thanks!
FTC Team 4008: 2009-2012
FTC Team 4602: 2010-2012
FRC Team 3481: 2010-2012
Unread 13-12-2011, 22:38
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
Re: [FTC]: FTC Ball Bearings
No. the only exception would be the really tiny ones from the tetrix pivot bearing kit. It looks big in the picture, but it is only just big enough to fit a #2 or 3 machine screw through the center bore.
EDIT: Actually, with any type of threaded rod under 3/8" being legal this year, one might be able to make this work for some light-duty applications other than the one it was specifically included in the kit for.
Unread 15-12-2011, 23:32
gotrobot?'s Avatar
gotrobot? gotrobot? is offline
Head Coach
FTC #5037 (got robot?)
Team Role: Coach
gotrobot? is a name known to allgotrobot? is a name known to allgotrobot? is a name known to allgotrobot? is a name known to allgotrobot? is a name known to allgotrobot? is a name known to all
Only if you can make them from approved materials stated in <R5C> of the rules.
Roller bearings should be somewhat easy but ball bearings, although doable, would need specialized equipment.
Does it have to be a ball bearing or just low friction?
2014-15 Cascade Effect: World Championship Inspire Finalist
www.facebook.com/gotrobot
