Thread Tools |
Rating:
Display Modes |
Heat sink on Cim Motors?
We're trying to be able to install heat sinks on our cim motors. There is a space restriction, so the heat sink should be no taller than 3 inches. Any ideas?
Don't ask why, just give suggestions. |
Re: Heat sink on Cim Motors?
You really don't want to post this type of question in Chit-Chat, many members block chitchat from their portal and don't check here often so they may have advice but may never see this thread.
If you are not willing to redesign and not willing to give more details so we can provide real advice then you can try to get whatever benefit possible from making your own, either by bending a flat heatsink, or there are a few instructables about making them out of things like soda cans and aluminum tape. Not a great way to get people to help you |
-Counter-Trolled (It is a joke on their name) Seriously though, look into PC heatsinks. They tend to be not too tall. That being said my real suggestion would be don't run your CIMS so they get that hot. |
... or mount the CIMs vertically. then the heatsinks will never be taller than the CIM.
Are you basically saying to do a barrel roll?
Liquid nitrogen will keep them cool.
The only realistic solution is to fabricate a clip-on, but that sounds like more trouble than it is worth. Read JamesBrown's answer, he's right about internal heat. Then think about the problem you want to solve - get heat away from the outer case. Um, won't a fan do that just as well?? |
Alternatively, blast your CIMs with canned-air coolant inbetween matches.
In 2008 we were burning up CIMs like crazy and I machined some aluminum heat sinks. As it turned out, they were rather worthless. In a controlled setup, they really did nothing to lessen motor heating, even with a large fan blowing directly over them. At about 15 Amps continuous load, after three minutes they were already too hot for comfort. The CIM motor heat is created in the armature and the only path out is through the bushings which is a rather poor heat transfer. It's not a continuous duty motor. It will heat, and there's really no great way to prevent it other than reducing the load.
Our team needs a replacement for the CIM for non-competition purposes.
Ideally they would have the same mating as the CIM and be a drop in replacement and be rated for continuous duty. Does anyone know of such a motor ? |
#10
What is the needed power output for this replacement motor? If you don't need the CIM's full power, I'd recommend a Banebots 775-18 with the CIMulator. Since the Banebots 775-18 has a fan, it should stand up better to continuous use.
Since I'm not particularly knowledgeable about motors, can someone please chime in and let us know how to find the best spot for continuous operation on a motor. I've heard it suggested that, for a continuously-operating motor, the best point to operate at to prevent overheating is usually the point of maximum efficiency. Is this correct, or is there a better metric? |
#11
