Physics Quiz 4
Figure1 is a top view of a block sitting on a table. The block weighs 10 Newtons. The coefficient of static friction between the block and the table is 0.8 (the same in all directions). A force F1 = 6 Newtons is applied to the block (yellow arrow). A force F2 (blue arrow) is then slowly applied in the direction shown. At what magnitude of F2 does the block begin to slide? |
Re: Physics Quiz 4
2*SQRT(7) Newtons
Re: Physics Quiz 4
For the benefit of students reading this thread, would you please show your work? Thank you. |
Re: Physics Quiz 4
F2 >= 5N and some change.
Spoiler for Work:
Re: Physics Quiz 4
Make the following changes to the original problem: - The static coefficient of friction in the "Y" direction (the direction of the yellow arrow) is mu_y = 0.8 - The static coefficient of friction in the "X" direction (the direction of the blue arrow) is mu_x = 0.2 - The static coefficient of friction varies linearly with theta from mu=0.2 in the "X" direction to mu=0.8 in the "Y" direction as theta goes from zero (X direction) to pi/2 (Y direction). Now find the value of Fx at which the block begins to slide. Last edited by Ether : 17-12-2011 at 17:35. Reason: added link back to original problem. |
Re: Physics Quiz 4
Spoiler for :
Re: Physics Quiz 4
You were doing great until you dropped the factor of "pi" on the left hand side in the very last equation. The numerical answer you got should have been a red flag that something was wrong.
Fix that, get a new numerical value for F2, then ask yourself "what happens when F2 = 2 Newtons?" Last edited by Ether : 17-12-2011 at 19:07. |
Re: Physics Quiz 4
F = sqrt(36 + F2^2)
F = 10*(.2 + .6 (theta/(pi/2))) theta = arctan(6/F2) F = 10*(.2 + .6 (2arctan(6/F2)/pi)) sqrt(36 + F2^2) = 2 + 6 (2arctan(6/F2)/pi) F2 ~= 2.491 N I'm confused; does this mean that it takes MORE sideways force to move the block than it would if there was no vertical force? For example, wouldn't the block move if F1 = 0N and F2 = 2N? |
Re: Physics Quiz 4
If you assume that the coefficient in any given direction is not increased by force components not in that direction, then the answer is that the block will start to slip when F2=2 Newtons. See attached "solution.pdf". However, these 2 assumptions: 1: linear change in mu for angles between 0 and pi/2, andare I think open questions. In FRC, there are wheels which are said to have different mu in the forward and sideways directions. I have looked but never seen any test data to show what happens when force is applied at a variety of angles between 0 and pi/2. Last edited by Ether : 17-12-2011 at 20:58. |
#10
Re: Physics Quiz 4
Plotting the "linear" model of μ vs θ in polar coordinates suggests it may not be a good model. Perhaps an elliptical interpolation between μx and μy would be a better model. See attachments. I haven't done the math yet, but I think the elliptical model will solve the "2 Newton paradox" discussed earlier in this thread. Last edited by Ether : 19-12-2011 at 11:22. Reason: added additional graphics |
#11
Re: Physics Quiz 4
#12
Re: Physics Quiz 4
![]() Quote:
#13
Re: Physics Quiz 4
Re: Physics Quiz 4
Jason |
#15
Re: Physics Quiz 4
Top view with respect to what, though? The table, or the plane the forces are acting on? The ambiguity of the question leaves it perfectly open to interpretation that the table is flush with any of the six faces of the block. Assumptions are useful in solving situations like this, but they can also lead to highly erroneous answers if they are wrong.
