Go to Post WE DEMAND FREE CORNDOGS FOR ALL MENTORS UPON ENTRY INTO THE EDWARD JONES DOME. #yourmovefrank - Jared Russell [more]
  #16   Spotlight this post!
Unread 20-12-2011, 01:24
roystur44's Avatar
roystur44 roystur44 is offline
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
roystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond repute
Send a message via Yahoo to roystur44
Re: pic: Sheet Metal Chassis Prototype
One of the cool things about sheet metal bots is that it is very easy to make multiple parts once the cutting/bending machine is setup. A second robot can be made in less time (minutes) than a tubular/extrusion based frame. Designed right the sheet metal frame tolerances are very high when compared to a cut, milled and welded frame. A sheet metal bot can use alignment pilot holes to locate brackets or use a tab and notch to locate parts during weld. I'm not saying sheet metal is better what I'm saying is it is a cost effective medium to make a robot out of if you have the right sponsors and mentors who can guide the students in the design.
A stiff frame is better than a flexible frame. The chain will stay aligned and taught. The manipulator will be more accurate and precise because it has a flat stiff base. Try shooting a ball into a basket on a trampoline. I've seen other robot drive trains just bend and break when ramming our drive base. We are building 120 lbs robots going 17' /sec. That is a lot of force on impact. Aim to build your robot light, stiff and strong and you can't go wrong.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
  #17   Spotlight this post!
Unread 20-12-2011, 11:07
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Originally Posted by Timz3082 View Post
Thanks for the feedback!
the gearbox is a toughbox mini with a 10.7:1 ratio built into the 1/8"" aluminum, this is a bit more reduction than we had last year and it worked great! by great, I mean we though it was the 2nd best drivetrain on the field! (2nd to 141 who had some crazy hyperspace swerve drive which after looking at for about 10 minutes, I still couldn't comprehend! I will now work on the modifications making this a more feasible, and realistic design! For the belly-pan, would there be anything wrong with using 1/2" Birch Plywood? It would be lightened and might end up lighter than aluminum, I will find out!
I like 1/2" birch plywood, 95 has used it in robot frames for year. I would highly recommend it.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
