pic: Team 3266 CAD project
Re: pic: Team 3266 CAD project
Great job.
Just a few questions. -Is there any reason you don't have any axles? -I don't see any sprockets. How do you plan on driving the wheels? -Is there a specific reason you chose the toughboxes over the supershifters? (My guess is cost) -Is the center wheel dropped? If not, you might want to change the front or rear wheels to omnis because it will be a nightmare to turn. |
Excellent start!
Essentially what Joe is getting at is to continue adding detail. You will find that the biggest benefit of CAD is having everything planned out before hand so that when construction rolls around there are no questions and it just flies together. You can make sure everything fits exactly how you need it to before cutting anything. So you're off to a great start, just make sure to pay attention to all the detail. Since this is just practice it's not as crucial but when build season rolls around it will be. One suggestion: I assume you are using dead axles, given the bearing blocks you have chosen. In that case, you might want to consider putting the wheel axles straight through the lower frame rails. This will give you some freedom in the vertical direction to get a drop on the center wheel, which you will need if you want to turn, and cuts out extra components. |
I chose the toughboxes over supershifters for cost and the simplicity. The center wheel is dropped 1/8" |
Great start on CADDING. I hope to see some of your work in the future. |
Just a tip:
McMaster has CAD models of many of the products they sell, including bolts and sprockets. It's great to help build up a BOM when you eventually build the robot. There's hardly an excuse to not have those bits modeled because it's a simple download if they have the parts you want. |
It is a 12.7:1 reduction, just the standard reduction they come with. I'll update the CAD tonight or tomorrow and repost it.
#10
How are the chains for the two back wheels set up? Specifically, are the wheels lined up (with the sprockets spaced out to line up with the drive sprocket) or are the wheels out of line (with both sprockets mounted flush with the wheel)?
#11
The sprockets are mounted flush to the wheels and the wheels are out of line. The back wheels have a slightly shorter base, but the middle and front wheels are in the center of the axle.
There's 24 bolts total that hold the axle mounts in place. If the robot is 150lbs that's 6.25lbs per bolt. Right now the axle mounts are designed to use 1/4"-20 bolts, but I might change that to 10-32 to save weight. |
#12
Your design is structurally superior, and your suggestions to improve strength is sound, but I believe the design is already strong enough. More reinforcement will only add weight. |
#14
Beautiful first model. Keep up the good work.
If you want a real challenge, then add chain runs (depending on the program this can either be a nightmare or a few simple clicks). Adding the chain runs will let you know how your wheels and sprockets are going to be lined up. |
