Go to Post Reading Andy Bakers post- priceless :D - thoughtful [more]
Unread 21-12-2011, 20:37
kws4000's Avatar
kws4000 kws4000 is offline
Team Mentor - Programming
AKA: Krazy Karl
FRC #2405 (Divided by Zero)
kws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the rough
Question Getting Encoder Position Value
Alright, here's a zinger:
C++[
float elbowencoder = encoder1->Get();
This would return a 4x value of it's position, so that I could figure out where it was and what to do with it at that point.
How would I accomplish this in LV?
Thanks.
Me, your local knucklehead.
Mentoring:
1) Educating students on the ability to learn and have fun at the same time.
2) Giving back to those who made you who you are.
2009-2011 Student 2405 Electrical/Programming & Asst. Captain
2012-???? Mentor 2405 Programming/Jack-of-all-Trades
Unread 21-12-2011, 20:44
plnyyanks's Avatar
plnyyanks plnyyanks is offline
Data wins arguments.
AKA: Phil Lopreiato
FRC #1124 (The ÜberBots), FRC #2900 (The Mighty Penguins)
Rookie Year: 2010
plnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond repute
Re: Getting Encoder Position Value
In LV, when you open the encoder, you have to specify 4x decoding. Then, you can just read the encoder value as a double. See the attached screenshot.
Phil Lopreiato - "It's a hardware problem"
Team 1124 (2010 - 2013), Team 1418 (2014), Team 2900 (2016)
FRC Notebook The Blue Alliance for Android
Unread 26-12-2011, 15:02
kws4000's Avatar
AKA: Krazy Karl
So distance is what I'll want if I want to know where I am in relation to startup?
So if I'm reading this right, rate will be used for, say, traction control?
Mentoring:
Unread 26-12-2011, 21:47
plnyyanks's Avatar
AKA: Phil Lopreiato
Rookie Year: 2010
That is correct. I forgot to mention, that when you open the encoder, one of the inputs to the Encoder Open VI is "Distance Per Count", which is the tangible distance per encoder tick (and I think it also factors into the rate calculation). Make good use of that parameter, and look into the VI documentation for some more information.
