1540 WCD
Hi guys, so I'm not sure which forum this should go to so I decided to put it here. This is our first year to make a west coast drive system, and from testing it at our BunnyBot game, it has proved to be fantastic. However, for the build season, I'd like to make more improvements to it and would like opinions and how to's.
The drive base is based off Team 221's super light chassis with our own holes to mount the transmissions. For our competition robot, we are probably going to use their supershifter adapters as well. These are the things I'm looking forward to change: 1. I'd like the chains to be on the inside rather than the outside of the frame. However, I'm not sure how to put the sprockets inside the supershifter adapter. 2. If we are unable to place chains on the outside, how would we mount the bumpers? Any other comments and suggestions are welcome. This is our current frame design: http://www.chiefdelphi.com/forums/at...d=13245415 24 |
Re: 1540 WCD
In 2008 we built a bracket that attached the bumpers to the frame.
http://farm4.static.flickr.com/3027/...4eafe022da.jpg |
Re: 1540 WCD
Re: 1540 WCD
By current (2011) bumper rules, it appears that those would be illegal, but without knowing the specific measurements, it's hard to say definitively. That's not to say that the method is flawed, you just may need more mounts of that style to comply with rules.
Re: 1540 WCD
Look at 254s gearbox. It's a good example of how to do this. |
Re: 1540 WCD
That looks like a good start, but you'll probably want to rethink your electronics layout. I don't think you'll be able to mount your digital sidecar like that because you'll be blocking your cables coming out of the digital module (unless FIRST changes the ordering to fill the first 3 slots), and you clearly can't bolt it down. It looks like you'll have space in front of your PD board for the sidecar.
I can't see everything, but will you have enough space to wire up your victors? Forgetting about wiring is so easy to do when you're trying to make things fit. |
Re: 1540 WCD
Re: 1540 WCD
For wiring the Victors, our control systems person was able to make a "Wire Spine" from all the victors going to our different electrical components. Again, we did make slight modifications before we made the robot. Sadly, my windows partition is dead so I couldn't upload the latest CAD |
Re: 1540 WCD
Another thing you can do is to move the entire transmission out away from the chassis so there is a gap, and then put the sprockets on the output shaft between the transmission and the chassis rail.
#10
Re: 1540 WCD
What's all the other stuff, like the pneumatics, for?
Also, how did you connect the corners - it's a little hard to see when it's all red. It looks cool, though. I wouldn't mind having a drivetrain like that this year. |
#11
Re: 1540 WCD
![]() Last edited by igeniusmint : 23-12-2011 at 04:56. Reason: link |
#12
Re: 1540 WCD
Ah, of course. I didn't realize you had actually used the 221 chassis; I thought that you had just based the drivetrain on the design.
Is the pneumatics for the stuffed bunnies? ![]() Last edited by Ninja_Bait : 23-12-2011 at 07:08. |
#13
Re: 1540 WCD
973 has a few pictures on CD-Media of this. http://www.chiefdelphi.com/media/photos/31603 http://www.chiefdelphi.com/media/photos/31604 http://www.chiefdelphi.com/media/photos/31605 Hope this helps. EDIT: Also attached is a picture of 48 and 3193s CAD of how they setup their WCD with Supershifters. Last edited by O'Sancheski : 23-12-2011 at 08:29. Reason: Changed team number from 294 to 973 cause of correction in later post. |
#14
Re: 1540 WCD
Re: 1540 WCD
My mistake.
