Go to Post I mean really, have you ever tried to schedule Dean and the scuba diving trainer in Manchester in winter? ;) - Billfred [more]
Unread 23-12-2011, 08:33
Biolore Biolore is offline
Lead Programmer
AKA: Josh
FRC #3597 (Robo-Rangers)
Rookie Year: 2011
Biolore is infamous around these partsBiolore is infamous around these parts
CRIO Fried
Our team's cRIO got fried during testing. Where can we get a new one?
Unread 23-12-2011, 10:09
tsaksa's Avatar
tsaksa tsaksa is offline
FRC #0997 (CHS Robotics)
Rookie Year: 2011
tsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond repute
Re: CRIO Fried
You should probably start by contacting National Instruments if it is really the CRIO. But first, exactly what happened and what is it doing now.
The first thing I would do is to check the power connections to the screw terminal block on the CRIO to make sure they are correct, and to check that you are getting power there using a volt meter. It is always possible that you have something much simpler wrong such as a bad connection, low voltage, a damaged power distribution board, etc.
This is the zeroth day of the rest of your life.
Unread 27-12-2011, 11:59
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
Re: CRIO Fried
National Instruments has a "return material authorization" (RMA) policy for repairing FIRST team cRIOs. If you have correctly wired up a direct power supply to the cRIO and none of the power lights come on, then this might indicate a blown fuse. Your Team Leader can call the RMA department from 7am to 7 pm CST at 1-866-511-6285 to set up a return.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 28-12-2011, 10:16
Lead Programmer
AKA: Josh
Rookie Year: 2011
Re: CRIO Fried
Well...
The power distributor is only outputting 12V from the 24V spot. We hooked up the cRIO to a separate source, and that didn't work either.
Unread 28-12-2011, 11:15
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: CRIO Fried
That sounds like a problem with the Power Distribution Board, and is unrelated to the cRIO. The 8-slot cRIO will not function with only 12 volts supplied to the power input.
What was the "separate source"? The first-generation FRC-cRIO wants at least 19 volts before it will power up.
(The newer 4-slot FRC-cRIO-II can work with as little as 9 volts.)
Unread 05-01-2012, 15:11
Lead Programmer
AKA: Josh
Rookie Year: 2011
Re: CRIO Fried
We hooked it up to 24 volts (about).
One of our mentors wants to know where we can buy a new cRIO as well.
Unread 05-01-2012, 15:16
Lead Programmer
AKA: Josh
Rookie Year: 2011
Re: CRIO Fried
We already shipped our cRIO in for repairs, and it should get here for the 18th.
