Go to Post It doesn't matter what goes wrong as long as you have fun. We all thought this was one of our best trips, even though we were second to last in our divison. - afowl [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 25-12-2011, 10:23
Yalib Yalib is offline
FRC #2630 (Thunderbolts)
Rookie Year: 2011
Yalib is on a distinguished road
Hex shaft
We are thinking about using HEX shafts for our drive train..
we searched the web and could not find shaft coupling or hubs...
did anyone work with HEX shafts and can help us with this?
Unread 25-12-2011, 10:56
Astechz_Nick Astechz_Nick is offline
FRC #2994 (ASTECHZ)
Team Role: CAD
Rookie Year: 2011
Astechz_Nick is an unknown quantity at this point
Re: Hex shaft
Are you looking for something like these?
http://www.andymark.com/product-p/am-0096.htm
Also have you considered investing in a hex broach?
Unread 25-12-2011, 11:04
jtus jtus is offline
AKA: Just Jack
Rookie Year: 1994
jtus is a glorious beacon of lightjtus is a glorious beacon of lightjtus is a glorious beacon of lightjtus is a glorious beacon of lightjtus is a glorious beacon of light
Re: Hex shaft
We use hex shafts all the time. Andymark.biz has hex bearings and hubs.
mcmastercarr.com has the shaft material. we use aluminum shaft to save weight. http://www.andymark.com/product-p/am-0096.htm
bearings http://www.andymark.com/product-p/am-0439.htm
shaft material http://www.mcmaster.com/#aluminum-alloy-rods/=fimtj6
Unread 25-12-2011, 11:26
Rookie Year: 2011
Re: Hex shaft
I meant bearings... like http://www.andymark.com/product-p/am-0160.htm but for a hex shaft...
Unread 25-12-2011, 12:10
FRC #2994 (ASTECHZ)
Team Role: CAD
Rookie Year: 2011
Re: Hex shaft
Contact AndyMark and see if you could switch out the bearings in am-0160 for bearings with the hex bore(which they sell btw). This seems like the simplist solution. They are closed for the holidays though so it might take a few days for a response.
Also if your team has the resources you could try to design and fabricate your own hub that would accept the hex bore bearing from AndyMark.
Unread 25-12-2011, 13:08
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
Re: Hex shaft
Why do you want the AM-0160 bearing hub (linked above) for hex shafts?
The AM-0160 bearing hub is designed to be used in a dead axle application (the shaft does not spin, and the sprockets are bolted directly to the wheel).
The only reason to switch to a hex shaft based design is to use them as live axles (the sprocket/gear/wheel all spin together with the shaft, with the bearings in your frame/chassis).
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 26-12-2011, 09:13
Rookie Year: 2011
Re: Hex shaft
Beacuse i want to place the gearbox inside the chassis and the wheels outside.. so i need a hub bearing so the live shaft can spin in the chassis profile..
Unread 26-12-2011, 09:16
Rookie Year: 2011
Re: Hex shaft
Does anyone know where we can purchase a hex shaft coupling?
Unread 26-12-2011, 09:43
Joe G.'s Avatar
Joe G. Joe G. is offline
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
Re: Hex shaft
It sounds like you don't need a hub, but just standard bearings. The simplest solution is probably to press fit something like this into your chassis rail. If you don't have the machining capabilities to press fit bearings this way, use something like this with the correct bore, and swap the bearing. Alternatively, you could use standard round bearings, and turn the ends of your shaft to a round profile.
Another consideration is, you don't necessarily have to support your shaft with your chassis rail. If your gearbox provides adequate support for your shaft by itself, you can just drill a clearance hole into the chassis, and let the gearbox's bearings do the work for you. It is almost never a good idea to support a shaft with more than two bearings, as this can cause binding.
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 26-12-2011, 14:47
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
Re: Hex shaft
It is also almost never a good idea to place the load on an axle far away from its supports. This is just another trade off to be considered, depending on the width of you chassis rails, this might not be an issue. If the rails are wide enough, it might be worth your time to try to align the bearings so the shaft can be supported. In situations where machining capabilities are minimal, narrower rails without additional axle supports might be the best option.
