Go to Post GP is an ideal to live by, but not a tool to judge with. - Rich Kressly [more]
Unread 26-12-2011, 12:49
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
A Simple Mechanical Calculator for Sine
I always got a huge kick out of watching this video that explains how the massive mechanical calculators they used to solve firing problems worked. It's 40 minutes long, but I've yet to meet an ME who didn't finish the whole thing once they started.
Some of the mechanisms are so cool, I made a really simple one as a Christmas gift. Essentially you move the pin to the angle you want to find the sine of, and by reading the location of the pin you can find the sine of that angle. By picking a location on the scale and then reading the angle you can find inverse sines too. And if you remember your trig identities (probably should've inscribed these on the face, they are hard to remember!) you can really do a whole lot more. I figured there are enough engineers here someone would be bound to get a kick out of it.
Video, in case my explanation doesn't make sense.
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 26-12-2011, 13:08
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: A Simple Mechanical Calculator for Sine
Very cool!
Al
WB9UVJ
www.wildstang.org
________________________
Unread 27-12-2011, 09:53
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Absolutely brilliant.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 27-12-2011, 13:41
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Equation of track: radius(θ) = a+1 + sin(θ)
"a" is the distance from the pivot to the "dimple" in the curve.
Attached figure "eqn.png" shows track curve for a=0.2
If you make "a" larger, say a=1, you can get a track with virtually no dimple (it may slide a bit smoother). See figure "no dimple.png"
ID:	11240  Click image for larger version
Name:	no dimple.png
