Go to Post Most of us are pretty friendly. - StephLee [more]
Unread 27-12-2011, 17:12
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Physics Quiz 7
Figure1 attached shows the top view of a vehicle with standard wheels
attempting to rotate counter-clockwise but not yet moving because the
torque being applied to the wheels is too low. The +Y axis is the
"forward" direction.
Assume the following:
- Four identical standard non-steerable wheels of radius "r"
- Wheels are located at the corners of a rectangle
- Axis of each wheel is parallel to the X-axis
- Coefficient of friction "mu" is the same in all directions
- The same magnitude torque "tau" is being applied to each wheel
- Let f2 = trackwidth/wheelbase
- The right wheels are being torqued “forward”
- The left wheels are being torqued “backward”
- The vehicle is in static equilibrium
- CoM aft of CoG. Vehicle is on a flat, level floor.
- Let f1 = (distance from CoG to CoM)/(distance from CoG to the point midway between rear wheels)
- Let W be the weight of the vehicle.
- Fn is the total friction reaction force of the floor on the bottom of wheel #n,
and Fnx Fny are its components. n= 1,2,3,4.
Problem:
Find the torque tau in terms of mu, r, W, f1, and f2 required to break the
static friction and start the vehicle rotating.
Unread 30-12-2011, 10:08
Ether's Avatar
Rookie Year: 1969
Re: Physics Quiz 7
Hint:
The Center of Mass (CoM) being located aft of the Center of Geometry (CoG) affects the front/rear weight distribution: the Normal force on the front wheels is less than the Normal force on the rear wheels.
This in turn makes the maximum available static friction at the front wheels less than the rear wheels. The analysis of the actual static friction forces* at the wheels, as long as they are less than the maximum available static friction, is unaffected by the weight distribution.
* i.e. the Fn force (with Fnx Fny components) at each wheel
Unread 30-12-2011, 22:50
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Re: Physics Quiz 7
It's the holidayyyys, ether, we can't do physics until after New Year's day!
I'll work on it tomorrow morning, I just forgot it was here.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 31-12-2011, 00:24
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
Rookie Year: 2007
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
Re: Physics Quiz 7
Ether,
This question seems to be a bunch of work meanwhile, it does not seem to get any interesting concepts across.
I read over it and it did not give me much inspiration to solve it.
-Borna Emami
Team 0x27
Unread 31-12-2011, 00:30
John's Avatar
John John is offline
AKA: John Gillespie
FRC #1153 (Roborebels)
Team Role: Mechanical
John is just really niceJohn is just really niceJohn is just really niceJohn is just really niceJohn is just really nice
Re: Physics Quiz 7
I assumed that the CoG is halfway between the front and back, if that is false pretty much none of this makes sense.
Fn(max) = Nn*mu
Since its symmetrical:
N1 = N2
N3 = N4
summing forces
W = N1+N2+N3+N4 = 2*N1 + 2*N3
summing moments about axis of front axles, defining wheelbase as 2 units
W*(1+f1) = (N3+N4)*2 = 4 * N3
combining formulas
W= 2*N1 + W*(1+f1)/2
W(1-1/2-(f1)/2) = 2*N1
N1 = W(1-f1)/4
F1(max) = F2(max) = mu*W(1-f1)/4
F3(max) = F4(max) = mu*W(1+f2)/4
summing moments around vertical axis through CoG
0=F1y*1+F2y*1+F3y*1+F4y*1-F1x*f2-F2x*f2-F3x*f2-F4x*f2
( F1x + F3x )*f2 = F1y + F3y
by Pythagorean theorem:
(sqrt((F1)^2-(F1y)^2) + sqrt((F3)^2-(F3y)^2))*f2 = F1y + F3y
Fny = tau/r
(sqrt((mu*W(1-f1)/4)^2-(tau/r)^2) + sqrt((mu*W(1+f1)/4)^2-(tau/r)^2)) *f2 = 2*tau/r
I spent around half an hour trying to simplify that but just made it worse:
sqrt((mu*W(1-f1)/4)^2-(tau/r)^2) * f2 = 2*tau/r - sqrt((mu*W(1+f1)/4)^2-(tau/r)^2)) *f2
(mu*W(1-f1)/4)^2-(tau/r)^2) * (f2)^2 = 4 * (tau/r)^2 - 4 * tau/r * sqrt((mu*W(1+f1)/4)^2-(tau/r)^2)) *f2 + ((mu*W(1+f1)/4)^2-(tau/r)^2)*(f2)^2
4*tau/r * sqrt((mu*W(1+f1)/4)^2-(tau/r)^2)) *f2 = 4*(tau/r)^2 + (f2)^2 * (((mu*W)^2*f1)/4)
16 * (tau/r)^2 * ((mu*W(1+f1)/4)^2-(tau/r)^2) *(f2)^2 = 16 * (tau/r)^4 + 8*(tau/r)^2 * (f2)^2 * (((mu*W)^2*f1)/4) + (f2)^4 * (mu*W)^4 * ((f1)^2)/16
Unread 31-12-2011, 07:50
Ether's Avatar
Rookie Year: 1969
Re: Physics Quiz 7
It is not a bunch of work; it is rather straightforward to solve. That is the interesting concept.
Unread 31-12-2011, 08:01
Ether's Avatar
Rookie Year: 1969
Re: Physics Quiz 7
Nice try. See note embedded below in red.
Fn(max) = Nn*mu
N1 = N2
N3 = N4
summing forces
combining formulas
N1 = W(1-f1)/4
You missed a major simplification here. What is the relationship between F1x and F3x?
Fny = tau/r
Unread 31-12-2011, 10:05
Ninja_Bait's Avatar
AKA: Jake Potter
Re: Physics Quiz 7
Solving each wheel generally for static equilibrium (from quiz 6):
1. Fny=Tau/r
2. Distance from wheel to CoG = sqrt(trackwidth^2+wheelbase^2)/2 and from now on is d
3. Fny*d*sin(angle included) = Fnx*d*sin(other angle included) because net torque is zero.
4. Fny(trackwidth/d) = Fnx(wheelbase/d)
5. Fnx = Fny*f = Tau*f2/r
6. |Fn| = |Fnx + Fny| = Tau*sqrt(f2^2 + 1)/r = Nn*mu
I think we only have to exceed the smallest static friction force (F1 and F2) to create a net torque on the bot so:
7. Tau*sqrt(f2^2 + 1)/r > N1*mu
8. Tau > N1*mu*r/sqrt(f2^2 + 1)
We can solve the forces in the yz plane for one side of the robot:
8. let wheelbase = b and distance from CoM to CoG = x
9. f1 = 2x/b
10. Tau about CoM (in the yz plane) is zero, therefore N1(b/2+x) = N4(b/2-x)
11. Divide by b/2, so N1(1+f1) = N4(1-f1)
12. Fnet is also zero, so W/2 = N1+N4
13. N1 = (W/2-N1)(1-f1)/(1+f1)
14. N1 = (W/4)(1-f1)
Now we can solve Tau in terms of givens:
15. Tau > (W/4)*(1-f1)*mu*r/sqrt(f2^2 + 1)
But I think I'm making the wrong assumption in the second section. If we have to exceed the greater static friction, Tau > (W/4)*(1+f1)*mu*r/sqrt(f2^2 + 1). I'm not so sure how the free-body diagram works out. On the other hand, I could be totally wrong altogether... (Thanks for the solution, ether!)
Unread 31-12-2011, 10:43
Ether's Avatar
Rookie Year: 1969
Re: Physics Quiz 7
Originally Posted by Ninja_Bait View Post
You got it.
Solution attached.
