Go to Post Would FIRST be as amazing if not for CD? I mean it would still be this amazing place for students and mentors to be but the explosion of innovation and gathering of people together across communities has to have been greatly effected by CD. - dodar [more]
Unread 30-12-2011, 14:52
Re: Disadvantages of swerve/crab
Originally Posted by Ether View Post
In the above context, "the best controls" sounds like you are referring to the driver interface. What driver interface did you finally decide was the best for your team?
Sure thing! Best is the wrong word too, "better" is the correct choice. We started off with a single 3D Pro joystick to control the drive system, but did not get a chance to figure something else out until later in the season which was using a joystick for throttle and then used the 3d joystick for rotation. It isn't best, but it was as far as we got before we decided to put off swerve until future offseason projects. But even then, we ended up using the override button on the joysticks which turned it into a 4 wheel tank drive most of the time.
Could you elaborate just a bit and list the top three (or whatever) things that made the learning curve huge and which took a long time to figure out? It might be helpful for other teams on the verge of making a similar decision.
I'd say some of the biggest issues we had were 1. being dumb and not using a 1:1 reduction for the rotation, 2. getting the modules perfectly synched, and 3. realizing too late that we should have used higher quality sensors than we did.
Big problem was that our drivers expected a perfect response time from the modules everytime they wanted to move somewhere, but our gearing and sensors significantly delayed response time.
Unread 30-12-2011, 14:57
Andrew Lawrence
Posts: n/a
How significant? Was it like major lag between controller input and movement, or more like a small yet noticeable change between input and movement?
Also, what gearing did you use, and which sensors? Which would you recommend of both?
Unread 30-12-2011, 15:09
It did what seemed liked a small change between input and movement sometimes, but later on that was fixed. The delay later on was, to me, significant because I did not know what to expect. It was just not instant as we all wanted, and I think this also happens to a lot of people when they first try swerve. The team might be under the impression that they'll get prefect turning and response from the get-go. However, with optimized systems such as 973, 111, 16, I suspect they see the kinds of results we expected: instant response (or close to).
As for the gearing, I'd have to go back to the CAD as I don't recall. The CAD should be somewhere on the Autodesk website from 2010 if they still archive that stuff.
Unread 30-12-2011, 10:21
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
Team Role: Mechanical
Rookie Year: 2007
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Even with a full practice swerve to play with and program, we had only just started to figure out the best controls for the swerve WHILE in Atlanta that year.
That's actually pretty quick as far as I'm concerned. 2079 built a prototype swerve before the 2008 season, we build a swerve drive for the 2008 season. We made our third iteration for the 2009 season. We just started to get it where we wanted it at the end our second regional in 2009. They have since ditched the idea of swerve do to complexity and lack of a fully intuitive algorithm for controls.
The real thing is that swerve is just harder to make well. It's not better or worse than any other drive train.
Unread 30-12-2011, 12:52
John's Avatar
John John is offline
AKA: John Gillespie
FRC #1153 (Roborebels)
John is just really niceJohn is just really niceJohn is just really niceJohn is just really niceJohn is just really nice
Theoretically, if you had unlimited resources, unlimited manufacturing time, unlimited programming time, and unlimited driver practice time, to build a "perfect" swerve drive, it would be clearly better than any other drive train. I would consider a "perfect swerve drive to be: all wheels independently powered, steered, shifting, never breaks , low weight, very low delays in turning the wheels, driver can intuitively control all functions, no repercussions on other systems.
Its pushing strength would be as good as a low speed skid steer,
its speed would be as good as a high speed skid steer,
its acceleration would be as good as any robot of similar weight,
its omnidirectional ability would be as good as mecanum/omniwheel drive
However, any real team does not have unlimited resources and time. As a result, most swerve drives do not achieve that performance. Some teams have gotten close, and these teams have generally been very successful, (148 in 2008, 111 in 2009). The problems with a swerve have to do with the real challenges of making one work like it is supposed to without massive tradeoffs, and not with any inherent disadvantage to swerve.
Unread 30-12-2011, 13:19
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
You didn't mention anything about waiving FRC rules, so I assume you are still limited to the legal type and number of motors.
I think the jury is still out on whether it is possible to steer the wheels on a swerve fast enough to make swerve "omnidirectional ability" as good as a well-built omni or mec.
Unread 30-12-2011, 13:32
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
Team Role: Coach
Rookie Year: 2007
Siri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond repute
Send a message via ICQ to Siri
What Jared said.
Also, FIRST has literal strategies that jack-of-all-trades swerve just isn't the best for. Of course, if you want to master a single "trade", swerve isn't necessary. But even if you want more, swerve gives you two things--reasonable holonomic-ness and reasonable traction--all the time. If you want, say, better holonomic drive sometimes and unmovable traction other times, something like switchable wheels/Octocanum could be better. Etcetera.
What is impractical about making a multi-speed swerve?
Depends. If you're doing a limited swerve/non-coaxial, adding a shifter isn't so hard. Maybe heavy, but at least you're not rotating it and probably don't need so many. In a co-axial, you're driving each wheel independently and rotating the drive motor/gearbox with the module. Adding a shifting mechanism gets really big and heavy (and expensive and complicated) really quickly. We do all our gear ratio adjustment via belt pulleys and planetary gearboxes. After two years of working on the drive, "impractical" still seems like a pretty good word for trying to mount an AM Supershifter on this, but maybe there are more streamlined shifters?
That said, we tend to win our pushing contests.
Originally Posted by AlexH View Post
Only effective if you have a good driver who can capitalize on the directional freedom that a swerve offers.
Moreover, only if you have enough good drive time with your chassis to get this capitalization experience. We've done poorly in this area for the first two years, but now that we have essentially optimized hardware, getting-close programming and excited drivers, this is huge.
Originally Posted by Aren_Hill View Post
I've got a few concepts that could hit < 35lbs for complete chassis with completely independent module power and steering, so weights only really an issue if you aren't trying hard enough
Wow, that's great! Our modules are at 9.1lb each with a 14.1lb chassis weldment. How'd you get it to 35lb total?
Unread 30-12-2011, 14:17
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
gblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond repute
One obvious disadvantage is the endless debate they engender.
One clear advantage is the endless debate they engender.
Blake
Blake Ross, For emailing me, in the verizon.net domain, I am blake
VRC Team Mentor, FTC volunteer, 5th Gear Developer, Husband, Father, Triangle Fraternity Alumnus (ky 76), U Ky BSEE, Tau Beta Pi, Eta Kappa Nu, Kentucky Colonel
Words/phrases I avoid: basis, mitigate, leveraging, transitioning, impact (instead of affect/effect), facilitate, programmatic, problematic, issue (instead of problem), latency (instead of delay), dependency (instead of prerequisite), connectivity, usage & utilize (instead of use), downed, functionality, functional, power on, descore, alumni (instead of alumnus/alumna), the enterprise, methodology, nomenclature, form factor (instead of size or shape), competency, modality, provided(with), provision(ing), irregardless/irrespective, signage, colorized, pulsating, ideate
Unread 01-01-2012, 18:33
Aren_Hill's Avatar
Aren_Hill Aren_Hill is offline
Build Nifty Things
Aren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond repute
Well over thanksgiving I rebuilt 1625's 2010 practice chassis (was 6wd swerve) into an 8 motor independent swerve, that came in a 41lbs,
Mainly its just sitting there staring at a concept going "how do i get rid of that....and why is that even there?" when looking at parts
current one i have almost ready to go is 6lbs flat per module (including CIM and steering motor)
A guy who likes robots.
1625->3928->148->1296->971 oh dear
Unread 01-01-2012, 19:37
Siri's Avatar
Dare greatly
Team Role: Coach
Rookie Year: 2007
That's awesome! Great job. Do you have CAD or photos?
Unread 01-01-2012, 19:38
Aren_Hill's Avatar
Build Nifty Things
That ones sitting nice and quiet in the back pocket till it gets used
Unread 29-12-2011, 20:34
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
A crab drive will push with as much torque as you gear it to. Just like any other drivetrain. A crab drive will be just as fast as you gear it. Just like any other drivetrain.
Drawbacks to swerve include the interior space required, reliability, and serviceability. In addition, swerves can struggle to handle rough terrain as easily as 6 wheel drives.
Of course that can all be overcome by engineering. There were swerves that were quiet effective at going over the bump in '10, and swerves that have had lifting modules to go up a "stair".
The big disadvantage of swerve is the amount of time you are going to take away from working on game specific facets in any given year. Anything other swerve disadvantage (again ignoring the complexity and difficulty in making it) is really just an engineering challenge that can be overcome.
I don't think you can really ask what is better without taking complexity and manufacturing difficulty into account.
