Go to Post Ive always wondered about this - if DK has an alter ego, like Clark Kent and Superman - KenWittlief [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 30-12-2011, 18:18
Chickenonastick's Avatar
Chickenonastick Chickenonastick is offline
Not a kebab
FRC #3256 (WarriorBorgs)
Rookie Year: 2010
Chickenonastick is on a distinguished road
Turning Off Command Alias Input
I like using the hotkeys in Inventor, i.e. C to Constrain, M to Measure... But recently Inventor has been ignoring these hotkeys and rather brings up "Command Alias Input" in the lower display bar. Does anybody know what's going on?
Unread 30-12-2011, 18:34
404'd's Avatar
404'd 404'd is offline
Lead contributor of sweg
AKA: Josh
FRC #0967 (Iron Lions (9-sits-7))
404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all
Re: Turning Off Command Alias Input
You can turn alias input completely off in the general tab of application options.
Tools > Aplication Options > General tab (2012)
Extra info here
Driving "Career":
2012 GKC: Quarterfinals w/ 6th seeded alliance | Wisconsin: Quarterfinals - 3rd seeded alliance captains
2013 GKC: Quarterfinals w/ 5th seeded alliance | North Star: Regional winners, 2nd seeded alliance captains
2013 CMP: Curie Semis w/ 2056 + 3990
Unread 31-12-2011, 03:13
Not a kebab
Rookie Year: 2010
Although the picture shows a part file, this is happening in assembly mode as well.
Unread 06-01-2012, 08:00
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
I am currently in Manchester for the Kick Off and will send a reply later today / tomorrow. This may be an OS issue that I have seen with how Inventor reads the keyboard input. Speak with you soon.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 06-01-2012, 10:13
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
FRC #0973 (Greybots)
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
The same thing was happening to me for a while with the 2011 build of Inventor. What it seems to mean is that there are multiple inputs with the same letter as you've entered. As in the example in the image, constraining would require you to press "C">"Enter". To change the commands or turn off alias input, go into your Application Options.
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
