Attaching AM Super shifters to chassis
I'm curious of different ways that teams have attached the AndyMark Super shifters to their chassis. I am mainly interested in ways that allow for direct driving to the wheels and leave it in the original casings.
Similar to how team 330 mounted theirs last year (see link). http://www.chiefdelphi.com/media/img...6fce0983_l.jpg If you could help me by explaining your teams method of mounting them, any problems you encountered, how they performed, and alternative ideas for mounting them it would be greatly appreciated. *I'm mainly looking for experienced opinions from people who have worked with SS before.* Thanks in advance! |
Re: Attaching AM Super shifters to chassis
I literally just designed this today
![]() So here it is. It mounts on the outside of the case using the four screws that hold the SS case together. This model is by no means finished (or tested), but we have done something similar in the past. Hope that this sparks someone's imagination. If you wan't to pursue this I can upload the finished version of this tomorrow (with a SS shown). Last edited by Garrett.d.w : 31-12-2011 at 02:50. Reason: completeness |
We have replaced the standard bolts and bolted through our frame with either 2,3 or 4 bolts, depending on our chassis.
We bolted ours right to the frame using slightly longer bolts than supplied by AM. Never had an issue, though, if I were going to do it again, I wouldn't bolt through the transmission, just through the face plate. Makes some service work a bit easier when one of the plates is still rigidly mounted.
Here's a picture of our 2011 mounting: http://www.chiefdelphi.com/media/photos/36163 |
I am not sure how you would do this. The existing bolts are thru bolts. Bolting thru the complete transmission makes sure the case stays "tight" and the gears stay aligned.
You could weld it, or there's always the expensive way.
Sorry. I was a little vague here. We discussed ways to make shifter maintenance a little easier by our second competition and one of them was to drill two extra holes in the outer face plate and use those for mounting. The through bolts would then just hold the trans together, meaning we could take the trans apart without removing the shaft to the center wheel. (Having to pull the center wheel was a big PITA on our 2011 robot, good thing we only did it once)
Otherwise, it would be impractical (which is easier to see now then it was at about 1PM).Long story short, disregard my earlier post. Way to expensive/ impractical to manufacture. |
#11
