Go to Post Safe zones are for the weak. - ChristopherSD [more]
Unread 03-01-2012, 10:47
Ja3 Ja3 is offline
FRC #3137
Ja3 is an unknown quantity at this point
Problem with a cRIO project
I have been trying to create a cRIO project, everything is created fine but when I try to upload it into the robot it says there is a break in the main.vi and when I enter into the main.vi block diagram there is no break what should I do?????
Unread 03-01-2012, 12:00
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Problem with a cRIO project
Errors often report Robot Main just because it calls everybody else. Robot Main is essentially your program that's made up of a bunch of sub-vi's. Take a look at the vi's you've modified from the default baseline to see if any of those front panel arrows are broken. The most likely candidates are: Begin.vi and Teleop.vi.
Are you using the Run arrow from the Robot Main.vi front panel?
or
Are you using Build/Run as Startup
Perhaps a screen shot of the particular error message or posting a zip of the project so we can help you find the error...
Break (as opposed to "The VI is broken") might refer to a program breakpoint in execution accidentally inserted into a sub vi like Teleop, but that's only effective when using the Run arrow. Breakpoints show up in the code as a red dot on a data flow wire as in the attached (red dot on the axis 2 (y) output wire).
