Go to Post Finding those students and giving them a lift up out of the sea of apathy that is constantly trying to drown them is one of the reasons I am in my profession. - Ben Mitchell [more]
Go Back   Chief Delphi > Technical > CAD
Unread 03-01-2012, 14:01
philso philso is offline
Mentor
FRC #2587
Rookie Year: 2011
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
KOP library for AutoCAD 3D?
Hello
I would like to ask a real CAD newbie question.
Is there a library of the KOP components that can be used in AutoCAD 3D (not AutoCAD Inventor)? I found a link to www.firstcadlibrary.com and they have compenents modelled for IGES, INV, SAT and STEP. Are any of these useable in AutoCAD 3D? My personal experience has been mostly in electrical CAD (board and chip design) so I have only heard of these terms.
Thanks.
Phil
Unread 13-01-2012, 12:48
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
Re: KOP library for AutoCAD 3D?
sat v 7 or earlier can be opened in AutoCAD (acisin command)
STEP and IGES can be imported in AutoCAD 2012.
Free Inventor Fusion will open these filetypes and convert to dwg http://labs.autodesk.com
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
AU 2007 Avatech Altogether Smarter Inventor Challenge 1st Place
http://home.pct.edu/~jmather/content..._tutorials.htm
Unread 13-01-2012, 13:22
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
If you are new to 3-D CAD, give serious thought to learning a non-AutoCAD product. Inventor, SolidWorks or Creo are free to FIRST teams, and far superior in terms of their parametric CAD capabilities, and each have sketch modes (for drawing 2-D profiles) that should be quite simple to understand with your background in 2-D CAD. 3-D mode in AutoCAD is a bit of a hack, and doesn't lend itself to more advanced analysis (structural, mechanism, thermal, etc.).
It's up to you to decide if a bit of familiarity (with AutoCAD) is worth more to your team than the other advantages offered by parametric CAD.
