Go to Post Holy 5-year-old-thread-revival Batman!! - Mr. Freeman [more]
Unread 03-01-2012, 21:22
CAPSMMR2410 CAPSMMR2410 is offline
FRC #2410 (Metal Mustang Robotics)
Team Role: Leadership
CAPSMMR2410 is an unknown quantity at this point
Lighter Robots
Every year our robot weighs in, within .5 lbs of the maximum. Do you guys have any recommendations for a lighter but still sturdy robot?
Unread 03-01-2012, 21:25
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Re: Lighter Robots
helium balloons!
Also, this white paper
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Almed Almed is offline
AKA: Arren
FRC #1197 (Torbots)
Team Role: Mechanical
Almed is an unknown quantity at this point
Re: Lighter Robots
Speed holes
Also, use 1/16th instead of 1/8th aluminum where you can
People often underestimate the strength of 1/16th aluminum rectangle.
Unread 03-01-2012, 21:27
CNettles11's Avatar
CNettles11 CNettles11 is offline
AKA: Chris Nettles
FRC #3502 (Octo-Pi-Rates)
Rookie Year: 2011
CNettles11 is a jewel in the roughCNettles11 is a jewel in the roughCNettles11 is a jewel in the roughCNettles11 is a jewel in the rough
Re: Lighter Robots
Think outside the box, but only by about 3 inches
Andrew Lawrence
Posts: n/a
Re: Lighter Robots
Use CAD to make your robot virtually, and then from there find out what you can do to shave off weight.
Also, sometimes being underweight can be bad. In a pushing competition, a 120 pound robot can USUALLY push a 100 pound robot, almost for sure if they have the same friction against the floor and same gear ratios.
256 likes to have their robots just at top weight, since we do love the power to push teams around the field (like when we pushed 254 half field at CalGames when they didn't go into low gear )
Unread 03-01-2012, 22:57
Joe G.'s Avatar
Joe G. Joe G. is offline
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
Re: Lighter Robots
If you don't weigh 119.99 lbs, you're missing something
That said, do detailed analysis of how much parts are costing you in weight. The more you understand where your weight problem is coming from, the better you can attack it.
Doing additional analysis on just how big a part you need is also helpful. Rather than saying "we've always used 1/2" shafts for the drive," learn how to do detailed stress analysis, to determine exactly how big your shaft needs to be. You'll find that these overly conservative assumptions can add up very quickly. A MAJOR culprit on this front is fastener use. It doesn't take much effort to determine how big, or how many bolts you need to hold a part, and yet many teams just go with their gut on this. Using too many fasteners, or larger ones than you need, adds up very quickly.
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 03-01-2012, 22:59
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Lighter Robots
Show us some pictures of your heavy robots, so we can see how they're made, and suggest different, lighter ways to do it
Unread 03-01-2012, 23:04
AlexH AlexH is offline
Rookie Year: 2010
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
Re: Lighter Robots
Tell your robot to lay off the McDonalds...
Why would you want a lighter robot? Heavier robot = more downforce on the wheels = harder to push.
Unread 03-01-2012, 23:06
MrForbes's Avatar
AKA: Jim
Re: Lighter Robots
Does the robot need to push other robots around? or does it need to zip across the field quickly? Weight is good for one, bad for the other
Unread 03-01-2012, 23:16
Re: Lighter Robots
Its more of, that we need a lighter frame so we can have (as in logomotion) a better arm that could work better. It would have needed a better claw which would have added more weight.
Also we were so close that we would have to take some stuff of because the regionals weighed us in at different weights. If we were a little lighter we wouldn't need to worry about being weighed different and taking things off.
Unread 03-01-2012, 23:32
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Rookie Year: 2010
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
Re: Lighter Robots
Keep in mind that its a lot easier to add weight than take it away at a competition. This should be the goal of every team especially with a tall robot(so you can add weight to the base).
This might even be a competitive advantage. If you make the robot underweight you could add weight to make the robot weigh 119.99lb(according to differently tuned competition scales).
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 04-01-2012, 00:10
engunneer's Avatar
engunneer engunneer is offline
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Rookie Year: 1996
engunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond repute
Re: Lighter Robots
A couple of points when considering robot weight, just from my experience:
- Make sure you use a reasonably accurate scale. Make sure it/they are tared correctly! (I saved us 4.4lb in '99 by noticing that we were weighing the scales)
- don't forget the electronics, especially wire. Whenever you weigh a pile of parts, just put the whole spool of wire on. Consider a "dummy box" that is full of random stuff that weighs the same as the electronics.
- Remember which parts you can't modify, and make sure everyone knows what they are! Don't be scrambling through tech inspection because a freshman put holes in a few motors to save weight. Make a "can't modify me" sticker for these items if you have to.
- During build week 4 or 5, review everything on your robot, and know what is required versus simply nice to have. Have a checklist of things you would ditch to save weight. make sure they are easy to remove. This is also useful for prioritizing what things still need to be built. Build the must-haves first.
- Remember your triangles and circles. Many things can be made of much lighter weight material if they are structurally sound, like triangles.
- Certain parts can be considered disposable! In 2009, out front cross beam (bumperless area) was 1/16" Alum. L instead of 1/8" because it saved on weight. We had to straighten it at least three times per comp, and had a spare. It could be replaced in a few minutes, and the pit crew could straighten the bent one while the robot was off at a match.
- Have a weight adding plan. In 2007, we strapped over a dozen Lead diving belt weights (plasti-dipped due to the lead-ness of them) tie-wrapped onto the robot. Because they were small and easy to attach, we put them in strategic areas. Each one added a little over a pound. We used them to move the center of mass of the robot more to the center, and closer to the ground. Never came close to tipping.
- Have a parent with a sense of humor that will duct-tape a 12" crescent wrench to the bottom of the robot three days before ship. Makes you think about losing weight sooner, and you get a few free pounds back when he fesses up.
- Consider welding your frame instead bolting it, if you intend to use many brackets. There is surely a local millwright or welder that will be excited to help out, and they are handy for other things too! Hardware adds up. Consider tapping holes instead of using a nut. Makes a great learning experience, and you only have to buy a few extra taps .
- There are many jobs that a tie-wrap can do just as well, or at least adequately when compared to other fasteners. Same thing with plastic/nylon bolts or nuts.
- Hollow shafts and tubing can save weight very quickly without sacrificing much in the way of strength.
- Know your safety factor on a design. A safety factor of 5 or more is simply adding weight. Also know which hole will take your safety factor from 3 to 1 and don't drill it (Another good item for stickers)
- You will be shocked to know how much weight you can get of of 1/16" polycarb with just a 1/2" hole punch and a couple of freshman-hours. (Actually only a few ounces)
Hope this helps!
Student FRC23 (1996-1999), Mentor FRC246 (2000), Mentor FRC1318 (2007-2009), Mentor FRC93 (2011), Mentor FRC2151 (2012), Mentor FRC23 (2013), Mentor FRC4761 (2014-2017)
1998 - National Chairman's Award and Woodie Flowers Award (FRC23, Mike Bastoni ) | 2007 - PNW SF (488, 1595) | 2008 - Oregon RCA - Seattle #2 Seed, SF (488, 1696) | 2009 - Oregon #1 Seed, Winners (1983, 2635) - Seattle SF (945, 2865) - Galileo #2 Seed, SF (973, 25) | 2012 Midwest F (111, 71) | 2014 RIDE Winners (78, 125), Inspector - NEU #24, QF (3479, 3958) - NECMP #35 | 2015 Reading #11, SF (1058, 190), Inspector - RIDE #17, QF(4055, 5494), Inspector - NECMP #57 | 2016 Reading #4, SF (133, 4474), DCA, Inspector - Ride #22, SF (1735, 2067), Creativity, Inspector - NECMP #48, RCA - Archimedes
Unread 04-01-2012, 00:14
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
Re: Lighter Robots
Lighter Robot?
http://xkcd.com/689/
...I couldn't resist.
Unread 03-01-2012, 23:49
MrForbes's Avatar
AKA: Jim
Re: Lighter Robots
We work on figuring out a light weight design for the "upper" stuff, and don't worry so much about the bottom of the robot. Once you come up with a basic design of how to make the manipulator stuff work, then spend a few more days thinking of ways to make it much lighter, using different materials, design ideas, etc. Our logomotion robot had a very light weight structure holding the arm, and the arm and claw weighed very little, and were made mostly with materials from the local building supply places like Home Depot and Lowes.
Lightweight stuff includes using thinwall square aluminum tubing and ABS sewer pipe, 1/4" plywood, thin Lexan sheet, thin aluminum sheet, etc. Figure out how to put things together with lightweight fastening methods, such as rivets.
  #15   Spotlight this post!
Unread 04-01-2012, 14:03
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
Re: Lighter Robots
True enough... but often at competitions you have to make repairs and/or upgrades to your machine. As you are doing them under the heat of competition, they rarely make your robot lighter.
In Toronto one year we weighed in at about 118.5, broke a component or two, fixed them up and strengthened them a bit and... then had to be reweighted for elimination rounds.
120.0 lbs.
I'd also suggest building your robot a little under sized in each dimension so that in the event of a major impact causing a slight frame twist (or adding a bolt to make a repair) you don't go from legal to illegal.
As a tech inspector I am always pleased when size and weight are mere formalities and not serious obstacles.
Jason
