Go to Post If you have a problem with a team, go to that team and address it with them. Don't air your slanderous opinions here for all to see. - Andy Baker [more]
Unread 07-01-2012, 16:15
ben7005 ben7005 is offline
FRC #1157
ben7005 is an unknown quantity at this point
Lasers?
Can we use laser range finders as a distance measuring tool, or is that not allowed? I think it would make it much easier to aim if we could find out how far the hoops are (exactly). The sonic range sensors only have a 20 foot range, and they can be interfered with by other bots blocking your sound waves.
Unread 07-01-2012, 16:23
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Re: Lasers?
See Blue Box, [R08]. Search is your friend.
(since 2004)
Unread 07-01-2012, 16:24
cbeavers6790's Avatar
cbeavers6790 cbeavers6790 is offline
AKA: carroll
FRC #3542 (Team S.P.E.E.D)
Team Role: Mechanical
cbeavers6790 will become famous soon enough
Re: Lasers?
Look at ro8 they say no lasers.
IM THE ENFORCER OF ALL RULES (at least the ones in the manual)
Unread 07-01-2012, 16:25
FRC #1157
Re: Lasers?
Thanks you guys. Pretty sad about this though...
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Re: Lasers?
Try again - they say no lasers with some exceptions.
(since 2004)
Unread 08-01-2012, 16:59
W1NG$'s Avatar
W1NG$ W1NG$ is offline
Team 2410
AKA: Alex Guinn
FRC #2410 (Metal Mustang Robotics)
W1NG$ is an unknown quantity at this point
Re: Lasers?
Your very right Gary! You can use laser this year as long as they are Class 1. But you have to keep in mind other rules that might make the use of even a class 1 laser if it is blinding drivers.
Unread 08-01-2012, 19:43
Dusk Star's Avatar
Dusk Star Dusk Star is offline
team Chief Delphi junkie
AKA: Andrew
FRC #2611 (Jacktown Vectors)
Dusk Star is an unknown quantity at this point
Re: Lasers?
Aren't all radar devices essentially lasers? so, following this (and skipping things like the 2.4 Ghz band, to avoid interference) could you use a radar rangefinder? After all, the first laser was in the microwave band!
Additional benefit- the MPE should be higher for lower frequency devices, allowing for a higher wattage.
Of course, this is probably all wrong...
