Go to Post Someone once said, "I know what finished is, and I know what a robot is, but what is this finished robot you speak of?" - EricH [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Unread 07-01-2012, 16:20
279 EMPIE's Avatar
279 EMPIE 279 EMPIE is offline
Head Progammer
AKA: Matthew Empie
FRC #0279 (Tech Fusion)
Rookie Year: 2011
279 EMPIE is just really nice279 EMPIE is just really nice279 EMPIE is just really nice279 EMPIE is just really nice
Send a message via AIM to 279 EMPIE
Kinect Programming
How do i go about programming the kinect-
>What language is it in
>Will the robot have to use this language
>can i be configured to java
>how does it connect to a computer
>etc...
I just dont know where to start :/
2011- Programmer, Electrical, and Web
Cleveland Regional
2012- Head Programmer, Web, Driver
Pittsburg Regional, Saint Louis International
2013- Head Programmer
Cinnicinatti Regional, Taraho Regional
Unread 07-01-2012, 16:23
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Re: Kinect Programming
Please take the time to read through the control system and kinect setup instructions and look at the kinect labview examples. They will explain a great deal about how it works.
Unread 07-01-2012, 16:26
279 EMPIE's Avatar
Head Progammer
AKA: Matthew Empie
Rookie Year: 2011
i dont have a kinect with me, i was trying to find information. Do you have a link to this?
Cleveland Regional
Unread 07-01-2012, 16:37
That Canadian That Canadian is offline
FRC #0346 (RoboHawks)
Rookie Year: 2010
That Canadian is an unknown quantity at this point
Our team programs in Java and I was just looking over some of the new Kinect Classes and Methods. You have to install the netbeans plugins to get the api for these methods and to use them, you can download the plugins here :: FRC 2012 Netbeans Plugins. There is a Kinect Object that you can create which you can call ethods getPosition and getSkeleton. Which will allow you to get various points on the persons body. That a brief overview that I've come across so far. Also there is a Kinect SDK you can dowload as well here. I haven't looked into that because you need windows 7 to install it and I'm at my XP computer. AS far as other documentation you should be able to find some more on FIRST's website and possibly microsofts's as well, although the Java API for FRC has alot of information on it.
Unread 07-01-2012, 16:53
279 EMPIE's Avatar
Head Progammer
AKA: Matthew Empie
Rookie Year: 2011
if i have last years .zip then do i only need update or do i need both?
Cleveland Regional
Unread 07-01-2012, 17:07
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Rookie Year: 2007
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
For me, it simply prompted that it had updates available for the FRC plugins, which I then ran. There is an additional Java plugin for command-based control that you might want to grab.
Note:
Netbeans, w/ automatic updates setup
Unread 07-01-2012, 20:08
alfredtwo alfredtwo is offline
alfredtwo will become famous soon enough
The official documentation for the Kinect and FRC may be found at http://firstforge.wpi.edu/sf/docman/..._documentation were you will find three documents:
•Getting Started with Microsoft Kinect for FRC document (PDF)
•Kinect Server Code Walkthough (PDF)
•Using the Kinect Kiosk (PDF)
You'll probably want to start there. I have posted those and other Kinect links on my blog at Kinect for FRC 2012
Alfred Thompson
Academic Developer Evangelist - Microsoft
Proud co-founder of Team 811
Unread 07-01-2012, 21:25
279 EMPIE's Avatar
Head Progammer
AKA: Matthew Empie
Rookie Year: 2011
Smile Re: Kinect Programming
I was just looking at the kinect sample programs and they dont seem to complicated for the autonomous. I cant seem to think of a way that i could use it to find the balls, targets if used on the robots.
Anyone know how to work with the kinect on the robot?
Cleveland Regional
Unread 08-01-2012, 19:23
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Lots of people know what it would take to make the Kinect work on the robot. Only a very small handful of those people believe it could be worth the added effort and expense.
My advice: if you don't already have a good handle on what you would have to do in order to connect a Kinect, don't worry about it. Just focus on building a robot that works without one.
Unread 09-01-2012, 22:33
Draycos214 Draycos214 is offline
FRC #2389 (Oklahoma STORM)
Rookie Year: 2011
Draycos214 is an unknown quantity at this point
https://decibel.ni.com/content/docs/DOC-20154
I found this PDF on how to link Kinect with driver-station, and program in LabView. Hope it helps!
