Go to Post FIRST isnt about getting what you deserve, FIRST is about other people seeing potential in us - and giving us an opportunity that we could never have earned on our own - KenWittlief [more]
Unread 09-01-2012, 20:22
jsmyth jsmyth is offline
FRC #3130
jsmyth is an unknown quantity at this point
Re: Bridges and Mecanum Wheels
the bridge is made out of polycarbonate, the rubber on the mecanum wheels will most likely cause more friction on this surface. sense these wheels rely on a lack of some friction for forward movment, will this increase in friction cause your robots from moving across the bridge or possibly slow you down.
Unread 09-01-2012, 20:25
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
This is a common misunderstanding. They do not rely on a lack of friction. See Post #12 earlier in this thread.
For more detailed explanation, there's lots of info here.
Unread 10-01-2012, 22:31
maxwellt's Avatar
maxwellt maxwellt is offline
what time is it? 540!!!
AKA: Tim Maxwell
FRC #0540 (Talon 540)
Rookie Year: 2010
maxwellt is an unknown quantity at this point
my team tested if mechcanum wheels could drive on the ramps which is made from white board material and all the wheels did was slide off of the white board so which means Mechcanum wheels will have no traction what so ever on the ramps, so they are not the way to go for the ramps
winning does not= trophies
winning = learning
FRC team 540's 2011 moto
Unread 10-01-2012, 23:43
372 lives on 372 lives on is offline
FRC #0372 (Robo-Knights)
Team Role: Mascot
372 lives on has a spectacular aura about372 lives on has a spectacular aura about372 lives on has a spectacular aura about
Originally Posted by Djur View Post
Team 2084 just tested out 120-lb robot from last year on a full-scale, functional bridge a mentor made for us. We could barely crabwalk (move laterally) up it, but the robot is really imbalanced, so that's not as large of an issue. The bridge was also surfaced with fiberboard, which at after a rough test we determined to have about 1/3 the CoF as HPDE like Lexan.
We'll also be getting a 48"x88" HDPE board soon, so we'll resurface the ramp and run the test again, but I can conclude that mecaums won't have too much trouble on the bridge.
could you two or other teams possible post a video so we can see. we do not have the resources to build a ramp quickly and need to see what it looks like.
cole?
