Go to Post 50% of the time that 330 used mcmaster 2717T51, we went to Einstein. Your mileage may vary. - Joe Ross [more]
Unread 07-01-2012, 17:52
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Rookie Year: 2007
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
<G28>
<G38> Robots may not touch an opponent Robot in contact with its Key, Alley, or Bridge.
Violation: Foul; Technical-Foul for purposeful, consequential contact.
This rule applied at all times, no matter who initiates the contact, see [G44].
<G44> Generally, a rule violation by an Alliance that was directly caused by actions of the opposing Alliance will not be penalized. Rule [G28] is an exception to this rule.
_______________________
You can intentionally cause fouls.
I'm Shocked.
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 07-01-2012, 18:06
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
Re: <G28>
*cough cough*
[G45] Strategies exploiting rule [G44] are not in the spirit of FIRST and not allowed.
Violation: Technical-foul and Red Card
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
Unread 07-01-2012, 18:08
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Re: <G28>
Based on this rule, it looks like you can receive a foul on your own side of the court if you are close enough to the opposing team's alley, and the opposing team comes to your side of the court and initiates contact with your bot while still partially in contact with its own alley.
Is this interpretation correct?
If this is the case, it seems possible to me that a robot can be in contact with its own key while at the same time make contact with an opposing robot in its own alley. (There's only 59" separation between the alley and key at the minimum).
In this situation, who is assigned a penalty?? Both teams??
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 07-01-2012, 18:09
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Re: <G28>
Oooo, that's a good one for the GDC when Q&A opens!
(since 2004)
Unread 07-01-2012, 18:11
Tetraman's Avatar
FIRST on my mind
AKA: Evan Raitt
Re: <G28>
It would be based on who hit who. If Red Alliance on their Key hits Blue Alliance in their Alley, Red alliance is called for the foul. If Blue Alliance in their Alley hits Red Alliance in their Key, Blue alliance is called for the foul. It's whomever does the move first. At least that's my interpretation and this is a good question to pose to the GDC.
Unread 07-01-2012, 18:15
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Re: <G28>
I don't believe this is the case. I believe that BOTH teams will get penalized, due to <G44>
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 07-01-2012, 18:17
Tetraman's Avatar
FIRST on my mind
AKA: Evan Raitt
Re: <G28>
Yea, good call Daniel. I retract my comments and state again it's a good question for the GDC.
Unread 07-01-2012, 18:20
seg9585's Avatar
AKA: Eric
Re: <G28>
I will definitely ask this, but one thing I did notice -- the penalty is a foul. A foul simply awards 3 points to the opposing team.
If both teams are penalized, each alliance receives 3 more points, so effectively there's no point advantage for either alliance (they cancel each other out).
My FIRST legacy:
Unread 07-01-2012, 18:41
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
Team Role: Teacher
Rookie Year: 2011
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: <G28>
I expect Team Update #1 to address some ambiguities like this.
Unread 07-01-2012, 21:05
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Re: <G28>
In the meantime, many teams are thinking of ways to build kitbots and just repeatedly touch opposing robots in their key and alley. Three points a touch is way easier to get than three points a hoop!
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 07-01-2012, 22:07
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
Team Role: Coach
Rookie Year: 2010
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: <G28>
Keep an eye out for <G45> though...
[G44] Generally, a rule violation by an Alliance that was directly caused by actions of the opposing Alliance will not be penalized. Rule [G28] is an exception to this rule.
[G45] Strategies exploiting Rule [G44] are not in the spirit of the FRC and are not allowed. Violation: Technical-Foul and Red Card
So if they are looking at ways to gain points by making contact and forcing fouls, the season is going to be a depressing one for them.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 07-01-2012, 23:01
koo_04 koo_04 is offline
FRC #2493
koo_04 will become famous soon enough
It states in rule G45 that it is not encourages and is not allowed.
Unread 08-01-2012, 00:08
rocknthehawk's Avatar
rocknthehawk rocknthehawk is offline
AKA: Aaron
FRC #1768 (Robo Chiefs)
rocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to behold
Re: <G28>
So if a red robot was parked in blue alliances alley, they would first incur a foul when touched by a blue robot, but then blue could be issued a technical foul and/or red card if continuing to hit the parked red robot? Where is the line between getting a robot out of your way, and exploiting [g44]?
Maybe I'm misunderstanding.
Unread 08-01-2012, 00:12
RayTurner1126's Avatar
RayTurner1126 RayTurner1126 is offline
team co-lead, mechanical lead
FRC #1126 (SparX)
Team Role: Leadership
Rookie Year: 2010
RayTurner1126 will become famous soon enoughRayTurner1126 will become famous soon enough
Re: <G28>
Said by one of my teammates: "I used to play in my opponent's alley like you, but then I took a G28 to the robot."
What time is it?? 11:26!!!
Go SparX on 3!!!
  #15   Spotlight this post!
Unread 08-01-2012, 00:16
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Re: <G28>
Wouldn't exploiting G44 be the other way? You would be exploiting it if you tried to get out of fouls, by having your opponent make the last move. I think it should say exploiting the exception in G44 if it means that.
(that noted, the interpretation here makes a lot more sense, I just wouldn't read it that way at first glance).
