Go to Post But their robot puts its wheels on one at a time just like ours, so we can be a HOF winner too! - Foster [more]
Unread 10-01-2012, 00:38
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
Rookie Year: 2007
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
Re: Tracking Rectangles
Originally Posted by mikegrundvig View Post
The whitepaper is extremely useful but the part I needed help with is actually what's glossed over the most. My understanding is that it's fully possible to determine both angle and distance from the target by the skew of the rectangle and the size. Here is a quote from the whitepaper:
"Shown to the right, the contours are fit with lines, and with some work, it is possible to identify the shared points and reconstruct the quadrilateral and therefore the perspective rectangle"
Except it stops there. Have any other reading or direction you can send us to take this the rest of the way? I'd really like our bot to be able to find it's location on the floor with the vision targets and unless we are straight-on, this is going to require handling the angle. Thanks!
-Mike
This varied depending on which language you use. If you aren't using Java, you should have access to a "convex hull" function, and a "find edge" function, which should do what you want. I haven't tested this yet, as I am using Java and do not have these functions. I'm working on getting them implemented in Java, but I have bigger fish to fry at the moment.
In theory, the bounding rectangle should be enough, if you put your camera as high as possible, and are willing to tolerate a little error. The height would tell you how far away you are, and the width, after accounting for the height, would tell you how far "off center" you are, giving you your position in polar form relative to the target. The error would be greater the further off center you are (since the perspective transformation makes the rectangle taller than it should be), but I would need to test to see if it is a significant amount.
Unread 10-01-2012, 11:58
Greg McKaskle Greg McKaskle is online now
The whitepaper is extremely useful ...
-Mike
There are a number of approaches, but I'll show the one that I would use -- not in code, but as an example. I'm also making a few simplifications to get things started -- notably, I'm often assuming that the camera and target are in the same vertical plane.
1. I open up the image shown in the paper into Vision Assistant (the one with the perspective distortion).
2. Use the third tool, the Measure tool to determine the lengths of the left and right vertical edges of the reflective strip. I measure 100 pixels and 134 pixels.
First image shows the measurements in red and green.
Since the edges are different pixel sizes, they are clearly different distances from the camera, but in the real-world, both are 18" long. The image is 320x240 pixels in size.
The FOV height where the red and green lines are drawn are found using ...
240 / 100 x 18" -> 43.2" for green,
and
240 / 134 x 18" -> 32.2" for red.
These may seem odd at first, but it is stating that if a tape measure were in the photo where the green line is drawn, taped to the backboard, you would see that from top to bottom in the camera photo, 43.2 inches would be visible on the left/green side, and since the red is closer, only 32.2 inches would be visible.
Next find the distance to the lines using theta of 47 degrees for the M1011...
(43.2 / 2) / tan( theta / 2) -> 49.7"
and
(32.2 / 2 ) / tan( theta / 2) -> 37.0"
This says that if you were to stretch a tape measure from the camera lens to to green line, it would read 49.7 inches, and to the red line would read 37 inches.
These measurements form two edges of a triangle from the camera to the red line and from the camera to the green line, and the third is the width of the retro-reflective rectangle, or 24". Note that this is not typically a right triangle.
I think the next step would depend on how you intend to shoot. One team may want to solve for the center of the hoop, another may want to solve for the center of the rectangle.
If you would like to measure the angles of the rectangle described above, you may want to look up the law of cosines. It will allow you to solve for any of the unknown angles.
I'd encourage you to place yardsticks or tape measures on your backboard and walk to different locations on the field and capture photos through your camera. You can then do similar calculations by hand or with your program. You can then calculate many of the different unknown values and determine which are useful for determining a shooting solution.
As with the white paper, this is not intended to be a final solution, but a starting point. Feel free to ask followup questions or pose other approaches.
Greg McKaskle
Unread 31-10-2013, 23:01
yash101 yash101 is offline
Curiosity | I have too much of it!
AKA: null
Rookie Year: 2012
yash101 is an unknown quantity at this point
Thumbs up Re: Tracking Rectangles
I have wanted to design a vision system to work like that and calculate the distance from the target without range sensors or any other sensors. I also wanted to skip the Kinect because of how hard it is to interface to the robot, and it's slow speed. This is exactly the routine that I wanted to do. Now, I know how to implement it. Thank You!
Also, if I am not wrong, does it follow the laws of perspective that explain how an image looks smaller as it is farther away from your eyes, in this case, the camera.
Here's and O: O
Look at it up close. doesn't it look large?
Now look at it five feet away. It should look much smaller now.
If I am not wrong, I think that is how this is supposed to work!
Unread 08-11-2013, 20:29
AKA: null
Rookie Year: 2012
Lightbulb Re: Tracking Rectangles
To isolate the rectangle, could I use a very high exposure rate camera, to reduce blur and to reduce the extraneous light, and have a very powerful light highlight the goals? Thresholding should get rid of the spare pieces, then binary conversion, then erode and dilate, then the other stuff done to find one box?
Unread 08-01-2012, 15:29
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
Rookie Year: 2007
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Originally Posted by davidthefat View Post
I was just trying to help, but I was merely trying to demonstrate the complexity of the issue. It is just not merely telling the cRio to find a rectangle and that there are many things going behind the scene.
I don't mean to attack in any sense, I think you should've offered this kind of explanation in the first place. I've seen you post the exact content on another thread too.
Personally, these types of papers are actually fun to read. Even if you only understand quarter of the math, the more you try, you start getting a bigger picture. I think it is more beneficial to butt your head and try going through this way first before using code already provided. It really builds character IMHO.
Completely agreed with this, reading papers is a skill that requires lots of practice. Another great thing to do is to read the WPILib code.
Unread 13-01-2012, 20:31
shuhao shuhao is offline
FRC #4069 (Lo-Ellen Robotics)
Rookie Year: 2012
shuhao is an unknown quantity at this point
I've seen posts about how ni vision + their own tracking code lags other robot functions. Plus, openCV has way more resource, and I also get to use things like standard python, or other languages
Maybe raspberry pi? Hmmm
Unread 13-01-2012, 23:11
FRC #1700
Rookie Year: 2007
It is working great for me, but YMMV. Proper threading should fix those problems. Using openCV in the CRIO would be very hard, as you would need to compile it for the CRIO to get that super fast C code. You should try both out and report back to us with some metrics, since I have nothing but my NI Vision code to speak for. Personally, I see no advantage to having the laptop on the robot, since the lag between the robot and the DS is negligible. Perhaps threshold on the CRIO, send the (much smaller) binary image to the laptop?
To address your earlier point about the legality of a laptop controller, all output to robot parts (motors, relays, etc) must come from the CRIO. You can send any signal you want to the crio, just not to anything else. Back in 2008 my team used current based speed controllers that were custom built circuit boards placed between the speed controller and the motor, and it was fun convincing the inspectors that they were legal
Unread 13-01-2012, 23:57
Rookie Year: 2012
Well. I need to send data back to the crio if i want to image process else where. Im not sending driving instructions to the parts from the laptop. the crio handles those . Im just processing the image and sending a couple of things back, like heading and location etc.
Unread 14-01-2012, 00:27
FRC #1700
Rookie Year: 2007
Right so it would be legal. But you should read the rules carefully; there is a max on the money spent on one part, on the motors (fan, hard drive, etc), power source (no batteries but the kit one, all power goes through distribution board). There is a reason very few teams go that route, and many teams are successful at image processing on the CRIO
Unread 15-01-2012, 10:28
RyanCahoon's Avatar
RyanCahoon RyanCahoon is offline
Disassembling my prior presumptions
FRC #0766 (M-A Bears)
Rookie Year: 2007
RyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond repute
Originally Posted by R48
The only motors and actuators permitted on 2012 FRC Robots include: [...] K. drive motors or fans that are part of a speed controller or COTS computing device
Originally Posted by R36
Batteries integral to and part of a COTS computing device are also permitted (i.e. laptop batteries), provided they’re only used to power the COTS computing device.
Luckily they've made this rather easier the last few years than when I tried it in 2008.
FRC 2046, 2007-2008, Student member
FRC 1708, 2009-2012, College mentor; 2013-2014, Mentor
FRC 766, 2015-, Mentor
Unread 15-01-2012, 10:56
mikegrundvig mikegrundvig is offline
FRC #2410 (Metal Mustangs)
Rookie Year: 2012
mikegrundvig is an unknown quantity at this point
My team is currently considering a single-board computer on the robot. You can get an excellent multi-core Intel Atom-based computer from http://www.logicsupply.com/ for a few hundred dollars. We've already checked with one of our regional inspectors and this would be completely allowed. The design would be:
Axis M1011 --> D-Link --> Atom (MJPEG stream)
Axis M1011 --> D-Link --> Wireless --> Driver Station (MJPEG stream)
Atom --> D-Link --> CRIO
CRIO <--> D-Link <--> Wireless <--> Driver Station
CRIO --> Robot electro/mechanical bits
The Atom would run a program (Labview, custom, whatever) that processes the image feed in real time and uses the network to talk to the CRIO. The CRIO would use this information internally to determine shooting solutions and send needed data down to the driver station so drivers know what's going on and what it's thinking.
The idea behind this is that it removes both the wireless network and the CRIO from the image processing loop at the expense of another piece of electronics in the system. The added horsepower comes at added complexity. The assumption though, correct or otherwise, is that an industrial-ish single-board PC is reliable and the code on the CRIO and driver station can still work great even if image processing fails. The specific configuration I listed above also keeps us with video feed unless the camera itself fails.
Only time will tell if it's a good idea or not
-Mike
Unread 16-01-2012, 16:11
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
I thought about that. The only downside is that it is no longer "batteries integral to and part of a COTS computing device ...". Thus, you have to run off the main battery.
The board may be COTS, but the battery is no longer "integral to and part of", and thus not an allowable battery.
Unread 18-01-2012, 12:19
PaulDavis1968's Avatar
PaulDavis1968 PaulDavis1968 is offline
Embedded Software/Systems Engineer
AKA: Master of Complexity
FRC #2053 (TigerTronics)
Rookie Year: 2012
PaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nice
I don't necessarily agree with that. I think a ruling on that would be needed.
Unread 18-01-2012, 12:20
Rookie Year: 2012
Actually, many single board computers have a power supply designed for car use where they can take from 6v to 24v. The power supply we are using does this for instance, making it well suited to the robot.
-Mike
